Author Topic: Lister Muffler Project  (Read 1158 times)
« on: April 03, 2021, 03:38:07 PM »
Some have had adequate noise reduction using a 25 lb propane bottle.
The idea I wanted to try was to have 2 bottles in series creating a first stage expansion, and then a second stage expansion.
I purchased two 5 gallon portable air compressor tanks and with the help of a welder friend, added a few threaded ports so that the two tanks could be screwed together.
Also added were 2 threaded ports for inlet and outlet.
The outlet port is oriented to allow a vertical stack to be added.
Below are pictures during construction....
Here are two videos of the tests that I ran.
I must point out that in both cases there is also an automotive muffler at the engine (which are almost useless on their own).
First is a test with the listeroid. I did this test before finishing and painting the unit in case it was a failure.
It turns out that the muffler did a fine job of almost eliminating the noise. (Neighbours cannot hear it)
https://www.youtube.com/watch?v=vRx_mrKnouU
Second test was after the unit was completed and connected to a changfa engine running at 1150 rpm.
You will note that the engine is mechanically loud indoors, but outside the muffler is extremely effective.
https://www.youtube.com/watch?v=EefDlxHy1uU
<click on pictures to enlarge>
Veggie
« Last Edit: April 04, 2021, 01:35:59 AM by veggie »
Re: Lister Muffler Project
« Reply #1 on: April 03, 2021, 04:03:35 PM »
Nice work, Veggie, that seems to have enough expansion volume to do the job nicely,
For my neighbor's DES 8/1 converted to propane project, we used a "leach-field muffler" using 3 inch leach-field rock in a trench with 2" holed pipe inlet and 4 inch plastic drain pipe outlet and 4" vent cap above ground.   That completely eliminates exhaust noise. It also cleans the exhaust odors; I recommend it where exhaust fumes coming back to home or workspace might be problematic.  It can be a bargain if done at the same time the septic leach-field system is being installed.  We used about 40 foot of trench, which is more than enough.
« Reply #2 on: April 03, 2021, 04:23:34 PM »
WOW! That is a dramatic reduction in sound.
dax021
« Reply #3 on: April 04, 2021, 09:29:13 AM »
Why don't you turn that outlet pipe to face downwards?  That way it won't fill your tank with rainwater.
CS Dave
« Reply #4 on: April 04, 2021, 11:48:48 AM »
Will you bury the tanks or keep them above ground?
1945 Lister CS 5/1 driving a sawbench
1963 Lister CS 8/1 Startomatic  4.5 KVA
« Reply #5 on: April 04, 2021, 04:06:31 PM »
As noted above, the outlet is positioned to accept a screw-on stack.
The vertical stack will extend up above my garage and will have a rain cap on top.
The stack will be 3" PVC pipe.
« Reply #6 on: April 04, 2021, 04:07:38 PM »
The tanks will stay above ground. I developed this muffler because I have no good location to bury one.
« Reply #7 on: April 04, 2021, 05:48:19 PM »
Excellent, Veggie.
Your expansion tanks work significantly better than my above ground maze made with concrete blocks.
I see in the youtube vid that you have a flexible hose connecting the engine and muffler. Where did you source the hose?
I would imagine a long length of that would absorb much pulse energy as well.
« Reply #8 on: April 04, 2021, 08:28:46 PM »
Hugh,
It's called crush proof garage exhaust hose.
Very flexible and rated to high temperature (600f intermittent). Don't use it directly connected to the engine.
I suspect it could run at 300 f indefinitely.
Available in 2, 3, and 4". The one in the vid is a 2 inch.
Here is an example...
https://www.new-line.com/hose/automotive-truck-marine-hose/garage-exhaust-hose-crushproof-flarelok/flarelock-rubber-garage-exhaust
I got mine at Greenline Hose and Fittings.
There is a branch in Vancouver.
or, here is an Amazon example.
https://www.amazon.ca/Dayco-63520-Garage-Exhaust-Hose/dp/B001PY4Y8Y/ref=sr_1_6?dchild=1&keywords=crush+proof+exhaust+hose&qid=1617564415&sr=8-6
cheers,
« Last Edit: April 05, 2021, 06:57:04 PM by veggie »
dax021
« Reply #9 on: April 05, 2021, 05:17:47 PM »
Sorry, my bad.  Didn't read properly
« Reply #10 on: April 05, 2021, 07:02:25 PM »
dax021,
Hey, no problem  ;)
A bigger concern for me was condensation.
Diesel combustion releases almost a quart of water as vapour for every quart of fuel burned.
With the muffler being located outdoors, there is a danger of water building up in the lower tank and then freezing whenever the engine turned off.
My solution was to drill a 1/2 hole at the bottom and weld on a threaded hub where I can screw in a ball valve.
During the winter I can crack open the valve and leave it open to drain any liquids.
We'll see if that works  ::)
« Reply #11 on: April 06, 2021, 01:03:39 PM »
Always glad to see you post another project Veggie.  Although I have no neighbors to worry about (thank God) I do get inquiries from shop customers that have noise concerns thus I follow engine muffling threads with interest.
My own stand by set is powered by a 1115 china diesel and even thought it is 200 feet from the house my wife complained about the noise. At the suggestion of a sound engineer I did 3 things and the reduction was remarkable.
I turned the exit vertical, added 20 feet of pipe to the the exit "above ear level" and increased the pipe size to lower exit velocity.  The results were outstanding. I think they could be improved further with the use of a double wall chimney pipe. I have been watching the used market for the pipe.
cujet
  • Lister power rules!
    • www.cujet.com
« Reply #12 on: April 06, 2021, 05:12:22 PM »
Very nice.
A couple of thoughts,
1) Just use a tiny hole on the bottom tank. Maybe you could drill your plug. It will release the water constantly. This is common on modern mufflers.
2) Consider a triple outlet "tip" using 3 different length and sized tubes. Tuned correctly, this can reduce the "thump" to 3 unevenly timed events, further reducing noise.
3) Consider a low outlet that turns towards the ground. Like a classic car tailpipe. This helps disperse noise and keeps water out.
« Reply #13 on: April 12, 2021, 09:35:35 PM »
 *** UPDATE ***
    SILENT RUNNING
The muffler was installed in my Listeroid system and a 4" ABS vertical stack was added to take the gases high and away from the yard.
A rain cap was fabricated at the top to protect four 1" holes drilled around the circumference of the pipe.
Success !   ;D
Here is a video of the result where I am standing 15 ft from the muffler.
(If you turn up the volume you can just here the exhaust)
https://youtu.be/75ffy41BcRY
« Last Edit: April 12, 2021, 11:56:55 PM by veggie »
« Reply #14 on: April 13, 2021, 12:12:03 AM »
Outstanding!
