Hi There fellow CS owners. I have a 1943 5/1 and an 1963 SoM 8/1.
I thought both could do with a full oil change - the book I have says 5 pints each. I took out the splash plate and cleared all the oil out and washed/flushed out the sumps and filters on both.
When I put them both back together and refilled the oil, 5 pints seems a bit too much (I refilled the splash area and ran both engines for 15 mins before re-checking the levels, all from the same 5 pint jug).
Some books say fill to an inch from the oil fill hole, I have seen others say fill up a bit higher. Both my engines would overflow if I put in the full 5 pints.
Its not a problem, I am just a bit curious.
