Author Topic: Welding from a Listeroid/ST generator rig  (Read 1886 times)
Martin
Re: Welding from a Listeroid/ST generator rig
« Reply #15 on: March 04, 2021, 12:07:24 AM »
In this picture the crank is at 9 o'clock when viewed from the front of the engine. So looking in through the crank case door gives a view of the bottom of the two kidney shaped counterweights.
Martin
« Reply #16 on: March 04, 2021, 12:12:03 AM »
This is a view through the crank case door with the crank at TDC, so we can see the sides of the two counter weights.
Martin
« Reply #17 on: March 04, 2021, 12:16:12 AM »
This one shows the crank at TDC, but the picture is taken at an oblique angle to show the kidney shaped profile of the counter weights.
Martin
« Reply #18 on: March 04, 2021, 12:21:16 AM »
Crank at BDC showing the counter weights at the top.
« Reply #19 on: March 04, 2021, 01:16:31 AM »
Martin, that type flywheel was used on the internally balanced engines with counter weights on the crankshaft. That flywheel should sit still on a balance stand in any position.
« Last Edit: March 04, 2021, 01:18:07 AM by 38ac »
highroad281
« Reply #20 on: March 23, 2022, 02:00:50 AM »
It was unfortunate that all my pictures were lost when the photo host shut down this the reason for the vanishing posts here.  No pics equals rest of post worthless. That being said an enterprizing individual happened to save all of my rants so there is hope at some point they will be available with pictures.
I’m aware that this is a cold topic but since I haven’t seen anyone else offering this up I figured I would. Maybe someone has and I missed it.  In that case please disregard the following.
Some years back I collected a both 6/1 and 12/2 clones with intent to go through them and build a back up gen.  I thought at the time that I’d like to have a hard copy of 38ac’s Indian build thread to work from, so I saved it to a doc.  Now that the kids no longer require constant supervision I’m hoping to pick back up on these projects and was quite dismayed to find the content gone, and myself unable to locate the doc that I had saved!
Well, after a few days of searching usb drives I have finally just found it.
With permission from the original author I’d be happy to share, drop me a pm.  Better yet if there is a way for a moderator to restore the content to the WOK from the doc that would be better still.
I’m positive that I also saved the twin build, and others (possibly timing, and balancing) threads too but unfortunately I think those are now lost to me.  If anyone happens to have the twin thread content to share I’d be especially grateful.
Best,
Neal
« Reply #21 on: March 23, 2022, 04:38:50 AM »
G'Day Neil,
That is a very kind offer and hopefully those who need it will contact you.
Something I would suggest providing the Admin approve is a new topic for listing all these manuals so they are easily found and looked up. Then anytime needs the information simply go to this new thread and find them there.
Is this possible to do please Admin?
olNick
« Reply #22 on: April 13, 2022, 11:19:41 AM »
Hi,
After cooking an expensive inverter welder connected to "cheesy" generators, I found that what kills them, at least in my case is the sudden voltage drop that occurs when striking a real arc (120-150A), tacking is ok...
This AC drop is enough to momentarily lose the 12V logic voltage so the welder is running w/o the control circuit, i.e. no PWM of the current.
I believe that it's a tossup as to which IGBT side clamps ON, thus full current, thus meltdown.
Maybe this could be remedied w/ a supercap or something in the control voltage PS.
Never, ever had a problem w/ my "real" 2 cyl DEUTZ, 6KVA, avr controlled generator. If anything it runs a lot sweeter when I'm wleding away....
Anyway, my 2c,
nick
« Reply #23 on: April 13, 2022, 12:34:05 PM »
Tghis site and another one I know of have a dedicated generator section with some very clever people to offer help with the right answers. Sorry I have no idea about generators but enjoy reading the problems and ways to fix.
Possibly duplicate the thread in the generator section or ask in that section to have a look at this and post a link of this in that section. If that makes any sense.
« Reply #24 on: April 13, 2022, 03:48:40 PM »
Oldnick, I think your assessment of the failure is interesting and quite possibly spot on.  Adding  large electrolytic capacitors on the 12V might be the simple solution.  But it is a very poor inverter-welder design that doesn't protect it's critical IGBT or Mosfet gate control from voltage sag.  Even if it did work admirably with a stronger AC supply.  All power electronics designers are not created equal; it's like any other professional, a brilliant minority and the rest barely getting by.
I'm in the latter group.  I popped a couple MOSFETs in my own home-hobby inverter design last week when I accidentally applied a hard short to the 120V (transformer stepped down) while testing a current/voltage/power smart sensor for a water chiller project. The 230V AC breaker didn't pop in time, and the DC fast blow fuse for that H-bridge blew but not quite fast enough, apparently.  This is the first failure ever of my inverter.  I never tested it for an overload/ short on the 120V side, only 230V.  Luckily it's all my own design so the repair was $8. in parts and a lost day.
I'm adding a fuse on the 120V side to protect me from future senior moments.  If it was a commercial design,  I'd add a microcontroller and circuitry watching the real time current to shut down the waveform generator in real time, safely as soon as a peak load exceeded the safe limit for peak current and/or time at peak.  Fuses are too crude.
olNick
« Reply #25 on: April 14, 2022, 11:21:27 AM »
Bruce,
Bit further on this, FWIW, my first shotgun repair attempt (simply replacing the IGBT's), lasted about 5 seconds before blowing up, since I did not check that I had pwm drive, before enabling the HV (SMPS-101 lessons here)
I bit the bullet, and read up to understand how inverters/SMPS work. Poking around I found that GDT had shorted/opened I don't remember.
Replacing that transformer brought back the PWM, and the thing started working again, with new transistors
The welder is/was quite advanced for a early 90's design, with a very high duty cycle. Specifically stated 8KVA generator minimum, my bad..
The "6KVA" chinese honda that did the damage, essentially almost stalled at that time...
anyway, I don't qualify for even 2nd group above, ha...
nick
« Reply #26 on: April 14, 2022, 04:02:23 PM »
olNick,
Bravo on that repair.
I expect a 90's design with IGBT's would not be power factor correcting, so it would need a much higher rating on the generator head to cope.
Inverter-welders have always been at the cutting edge of power designs.  I can't imagine a more difficult power design application; high current arcing and shorts are normal.
« Reply #27 on: April 18, 2022, 08:04:27 PM »
Fwiw we use a couple of $400 180A inverter welders at work (one of which belongs to me, personally) off of a Chinese generator and have done so for over a decade at the cost of just one welder, which was very second-hand at the time, anyway.  We use an 11kVA generator and it doesn't really notice when the load comes on - no real drop in revs or whatever.  I have been told that is the secret to looking after both generator and welder.  Our local hire company won't hire you anything smaller than about 15kW if you tell them you're welding - they say it "blows up" the generators sometimes too.   Cheers
