Author Topic: TS-2 injector pump issue  (Read 1349 times)
Flintgreasewood
« on: January 22, 2021, 08:03:37 PM »
One of the two fuel injector pumps on my TS -2 is getting fuel but not putting any out to the injector. What might be going on?  Possible contaminant inside? Can the pumps be disassembled and serviced by myself or only by a reputable technician?
Re: TS-2 injector pump issue
« Reply #1 on: February 17, 2021, 03:06:30 PM »
Those TS pumps can be dismantled and cleaned or restored with new parts... a bit of a tricky deal to do the job without damage to the retaining bits. There is a specialized stake to keep the plunger from slipping out of the control mechanism. Do not force anything, use reasonable care and clean everything to the Nth degree, you should be OK.
