So I wonder where this leaves the humble Petter?
It has an oil filter and full presure lube, but its also a 1949 design with babbit on brass bearings. I always believed in detergent oils in everything I use. I change oil like underware, and this seems to have served me well.
Now I have to scratch my head, I realy don't know what to run in my 10-1
I'd say it falls in the same category as a lot of other diesels with full-flow lube and not-very-tight tolerances. If you're running normally aspirated, I strongly doubt that you're going to get the oil hot enough to coke. If that's the case, then you may want to worry more about resting time and oil below 160 F entraining water than you should about high-temp oxidation, breakdown, or detergency.
If it's going to be running most of the time, do whatever must be done to keep the crankcase temp in the 170+ range when running, then pick a diesel-grade multi-vis detergent synthetic with a big bottom number. Something like a 15W40 would work well. Use a bypass filter with it and run the oil for years at a time. Yes, the oil might be a little thin until the engine gets hot, so you might want to run it at 1/3 load until it gets warm after a shutdown, but in steady-state it should be happy.
If it's going to be sitting most of the time, put fossil oil in it. You need to change the oil every 6 months or so anyway to get rid of the water. I'd try something like a 20W50 with some diesel rating. Frankly, your tribology problems are simpler than those of we listeroid owners...
Now, after having made a recommendation, I'm going to throw a wrench (oh, wait, it's Whitworth, so I guess it's a spanner) in things:
In the USA, at least, multigrade oils that meet the needs of listeroids and petteroids are about to get a lot rarer. It's all EPA's fault (again). They want ZDDP (Zinc Dialkyl Dithiophosphate) out of engine oils because it poisons catalytic converters. The problem is that ZDDP is almost the best shear resistance additive we've got. Things are looking bleak for engines with sliding-contact tappets or gear driven cams, and Listeroids and Petteroids have both. This is an issue that is starting to get a fair amount of coverage in the motorhead press. Motorcycle guys have worried about this for some time (transmissions run in engine oil), and now everybody with a 55-93 (or so) small-block chevy is in the crosshairs as well. I know about this because my Corvairs also have sliding contact tappets and gear drive cams.
We seem to be going back to the days of yore when you had to add stuff to the oil just to avoid premature engine death. Frankly, I think it blows. The good news is that your friendly GM dealer has been ordering cases of GM camshaft and lifter prelube (PN 12345501) lately, because it's now a GM requirement that oil changes done on cars with non-roller tappets get a shot of the stuff because of all the ZDDP not in the (API SL-rated) oils they keep around the shop. As a result, they will happily sell you a bottle for a reasonable fee. Right now, you can escape by running a diesel oil, but, since diesels are all going to be required to run cats for NOx control very soon, the "no ZDDP problem" is about to get a lot more common.
Here are some articles I could find online that give background on this:
http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/http://www.highperformancepontiac.com/tech/hppp_0606_understanding_motor_oil/index.htmlBTW, GM EOS GM EOS assembly lubricant (PN 1052367) has loads of good stuff your new listeroid or petteroid would like to have in the sump at first start up. No, I'm not a GM dealer in any form, but it's good stuff, and is recommended by all the car aftermarket cam manufacturers for break-in of a new cam because it's cheap, readily available, and works.
I have absolutely no idea how this relates to folks in Canada, the UK, or Europe. I'm guessing that Canada is going to get stuck with the same junk we're getting, and I sincerely hope that the EU are having an attack of sanity about it, like they eventually did about British beer in pints.
