Removing the camshaft CS6
Owenga:
Thanks..
I did support the shaft and hit the pin with a decent hammer , it’s really stubborn, I have sanded the ends down to remove burring, now I will heat it and hopefully punch it out....
Where can I get replacement pins from, and do you know the degree of taper (I might need to make them ) .... ?
Owenga. ( it’s a bay on Chatham island where I live )........
38ac:
Those are a #6 taper pin. In the states I buy them from McMasrter Carr
Edit,
I am pretty sure they are #6 but don't rush to buy until I double check that
broncodriver99:
You are correct 38ac, they are #6 pins.
mikenash:
Owenga we're almost neigbours. Do you know about the Lister Spares chap in Oz? Just google oldtimer engines. Very helpful chap. Never a problem posting stuff to NZ for me. I've got the bottom end of an old 3/1 in the yard - been sitting for a while so might be rusted solid - but if you get stuck I could see if the cam would come out? Cheers
[*] Previous page
