Author Topic: Lister CE rod bearings  (Read 3125 times)
Mtour
« on: October 28, 2020, 02:06:21 PM »
Hi
 Anyone know of a source for rod bearings (23/220) for a lister ce. Not sure if other models, like a jp would work. Also has anyone had these bearings rebabbited and what the cost would be..
Thanks..
sinna42
Re: Lister CE rod bearings
« Reply #1 on: October 28, 2020, 02:48:08 PM »
Hi,
I don't think the JP big end bearings will suit - they have a part no 10-4-8.
Jim
Lister CS 3/1 1938, Lister CS 3/1 1939, Lister H4 Pump, Coventry Victor AN4 Mk1 1944, Gardner 1L2 1962
Mtour
« Reply #2 on: October 28, 2020, 03:11:10 PM »
There listed as 23/220..
listard-jp2
« Reply #3 on: October 28, 2020, 06:45:58 PM »
I don't know if you require STD or an undersize, but here is a link to some on ebay at present @0.010" undersize (with care they could be resized back to STD and would still be cheaper than having your old shells remetalled
https://www.ebay.co.uk/itm/Lister-ROD-bearings-010-CE-16-41-2-x-43-8-engine-Vintage-NOS/113961646623
Mtour
« Reply #4 on: October 29, 2020, 10:40:34 AM »
Thanks for the link....
« Last Edit: October 29, 2020, 10:55:40 AM by Mtour »
Mtour
« Reply #5 on: November 01, 2020, 12:25:55 PM »
Hi
 Anyone know what the stock rod journal size would be on the CE crank, trying to figure out what rod bearings are needed.
Thanks..
listard-jp2
« Reply #6 on: November 01, 2020, 04:33:15 PM »
Standard big end journal diameter is 2.7475" / 2.748"
Connecting rod big end bore is 3.125" / 3.1255"
Finally the Glacier Pt# for these bearings is B2017M
The above information was taken from a 1979 Glacier/AE replacement bearing catalogue
Mtour
« Reply #7 on: November 02, 2020, 11:04:20 AM »
 Hi
   That's just what I was after, I ordered a micrometer and it should be here Monday. Now I'll just have to figure out how to read it....
 Thanks
Mtour
« Reply #8 on: November 04, 2020, 09:58:58 PM »
The journal measured 2.737"...
 I was able to purchase the 0.010" from ebay..
 Thanks for the help...
Lister Rob
« Reply #9 on: January 19, 2021, 10:31:25 AM »
 looks like that bearing was put on to tight and not shimmed .
