Author Topic: Lister CS 3.5  (Read 2108 times)
littleridge
Lister CS 3.5
« on: October 09, 2020, 06:04:54 AM »
Hello Members
What is the correct ring gap for new parts ,Rings and liner.
thanks.
Re: Lister CS 3.5
« Reply #1 on: October 10, 2020, 01:53:56 PM »
It is not mentioned in the technical specifications but in my 6/1 manual the minimum end gap is .012". A 3/1 would be slightly less due to smaller bore. I would go with .010"  Be sure to check the side gap in the top groove as they take a beating. restoring side gap is far more important than end gap as for restoring compression.
littleridge
Re: Lister CS 3.5
« Reply #2 on: October 19, 2020, 05:00:22 AM »
Thanks 38ac,I was on the same lines.
