Hi all, newbie here both to the forum and to diesel generators!
I've been asked to try getting an old Lister-based Brush generator to run. It has a control box sort of thing with a cable that goes into the doghouse. What I'm not sure of is how the two cores from this cable are wired up in there. As you can see from the photo it seems there are two possible connectors- L1 and L2. If I'm correct in thinking that's where I need to connect to, does it matter which connector the live and neutral go to, or can it be either?
I hope that makes sense- I've attached pictures of everything I think might be useful. Thanks in advance for any and all help you might be able to give.
Generator
Doghouse
Doghouse Connectors with L1 & L2 shown
Control Box Thingummy
