Author Topic: timing adjustment for WVO to reduce carbon build up  (Read 4341 times)
Re: timing adjustment for WVO to reduce carbon build up
« Reply #15 on: October 14, 2020, 05:55:54 PM »
Inlet and outlet hose temps near the head should suffice.
Measuring load amps or watts is also important.
Don't add water injection until the engine is fully up to temperature.
« Last Edit: October 14, 2020, 05:58:11 PM by BruceM »
« Reply #16 on: October 14, 2020, 10:26:55 PM »
I have a 195F thermostat on mine, and the top of the head gets up to temp in about 20 minutes with a 2500w load (It's often starting with 40F environment) and I'll try to get some measurements this fall when the cloudy season starts
