Author Topic: Lister BA2  (Read 2201 times)
Mirjan
Lister BA2
« on: July 15, 2020, 06:47:51 PM »
Hi, good evening,
I am looking for an Instruction Manual / Operator's Handbook for a Lister BA2 (2 cyl. / 25 bhp / aircooled).
I searched the net but did not find any adequate documentation. Any idea where to find / obtain ?
Need it for this "Little Lady"  ;): https://www.youtube.com/watch?v=5AQT9rtuUJo
Thanks / Greetings
Michael
« Last Edit: July 15, 2020, 06:49:40 PM by Mirjan »
Mirjan
Re: Lister BA2
« Reply #1 on: July 21, 2020, 09:59:47 AM »
Hi, good morning,
although the search for BA2-Manual wasn't successful yet we managed to "re-animate" the motor after six years not running  ;D
https://www.youtube.com/watch?v=T6hG1HHOyCY
https://www.youtube.com/watch?v=lHu8jebl5Xs
Next step is a new packing for the sterntube / prop-shaft and then back to water  ;)
Greetings Michael
« Last Edit: July 21, 2020, 10:07:40 AM by Mirjan »
sirpedrosa
Re: Lister BA2
« Reply #2 on: July 21, 2020, 01:06:25 PM »
Hi Michael
That engine, from what I can see it could be a ST2 or SR2 model, and its easy to find manuals.
Can you put a pic of model and serial plate here?
Are you shure is it 25HP?
BR
VP
« Last Edit: July 21, 2020, 01:45:13 PM by sirpedrosa »
By order of firing up:
Mirjan
Re: Lister BA2
« Reply #3 on: July 21, 2020, 07:28:33 PM »
Hi,
will try to make some pics next days, but it's so "bloody" narrow in the boat to get a good picture.
Serial Plate I will look for.
The only plate I found so far is stating following: "8,5 hp @ 1.800 rpm" ?????
Thanks so far.
Greetings
listard-jp2
Re: Lister BA2
« Reply #4 on: July 21, 2020, 08:28:30 PM »
/\ /\ Beat me to it :)
Furthermore it will not be a ST2 as that engine has two of the four cylinder head nuts exposed, and as a result has a different style of rocker cover.
Agreed it is most likely a Lister SR2*, and the engine type will be in the middle of a long string of numbers that also comprise of the serial number. The data plate is usually attached to the injection pump inspection door.
Though it could also conceivably be a Lister SL2, LD2, or LR2.
sirpedrosa
Re: Lister BA2
« Reply #5 on: July 21, 2020, 08:38:40 PM »
Hi gentles
Yes, I would incline to SL2, with 8,5@1800.
BR
VP
Mirjan
Re: Lister BA2
« Reply #6 on: July 21, 2020, 10:15:28 PM »
...I would incline to SL2, with 8,5@1800....
Great, thanks. Anyway I'll try to find the data plate.
Rgds Michael
listard-jp2
Re: Lister BA2
« Reply #7 on: July 22, 2020, 06:38:05 PM »
/\ Lets hope it's not a SL2 for your sake, as the SL is tricky for certain spares that are unique to that engine.
If it is SL the outline of the cylinder barrel fins will be circular, compared to the SR which will be square in outline.
This is not a totally reliable indicator, because a round outline can also indicate LD2, just as a square outline could also indicate LR2
