Author Topic: Lister  (Read 1453 times)
Govenor
Lister
« on: June 29, 2020, 04:06:55 PM »
Hi can anyone tell me if you can run a lister l T 1A 19. In the opposite direction.
« Last Edit: June 29, 2020, 04:46:25 PM by Govenor »
Re: Lister
« Reply #1 on: June 30, 2020, 07:22:52 AM »
Not a good thing to try and run them backwards at all. to change the rotation is a bit of work but can you get the reverse rotation by driving off the opposite end of the crank shaft and if it is a crank start change to electric or make a starting dog for the other end.
Out of curiosity, what is the application?
listard-jp2
Re: Lister
« Reply #2 on: July 02, 2020, 07:52:22 AM »
/\ That is one option, but those LT engines have a very spindly camshaft, also it will be at 1/2 engine speed.
However here is a link to another thread, by someone who managed to achieve that albeit unintentionally.
https://listerengine.com/smf/index.php?topic=9009.0
To change the DOR of a Lister engine is a lot of work, and you will need to replace the following:
Camshaft, starting dog, starting handle, flywheel fan shroud, and flywheel fan. No need to change the oil pump as these are a plunger design.
Easiest way to achieve this is to find an identical scrapper reverse rotation Lister engine and swap the bits over.
Edit: You will  also have to change the flywheel end crankshaft oil seal, because although these engines have a rubber lip oil seal it usually has a preferred direction of rotation, as it has a scroll molded into the sealing surface.
« Last Edit: July 03, 2020, 08:19:48 AM by listard-jp2 »
