Author Topic: Direction of rotation  (Read 1201 times)
jrcplant16
« on: June 09, 2020, 06:43:48 PM »
Evening to you all and thanks for accepting me on here.
Can anyone advise me how to change DOR on a PH2?
Is it as simple as a camshaft and starter swap?
Thanks very much,
Jez
listard-jp2
Re: Direction of rotation
« Reply #1 on: June 09, 2020, 08:13:45 PM »
In a word No.
You will also need a reverse rotation oil pump, and a different flywheel cowling.
If you contact Jim Perkins an expert on the PH engine range
 http://www.petterengines.co.uk/
He may have the parts you require
jrcplant16
« Reply #2 on: June 09, 2020, 08:58:05 PM »
Hello, thanks very much for that information.
Jim sounds like a very knowledgeable guy. I shall have a chat with him.
Thanks once again.
sirpedrosa
« Reply #3 on: June 09, 2020, 10:31:51 PM »
Hi Jrc
I think you want to "make pass a oil tanker in the thames river at Teddington"
1st, yes Jim Perkins is (by now) the most reliable (and the most honest) British I met!
2nd, you can get reverse power, or as we say PTO (power take off) by putting the extended shaft attached in the crank gear, instead of cam gear.
As far as my Petter studies reaches, I didn't find, so far, any reverse Petter, but.... we never know!
Just my 5 cents!
BR
PS: My apologies I found one vid with a reverse rotation, see here: https://www.youtube.com/watch?v=RHnfOdF6q_Q
PS2: and I also find a moron: https://www.youtube.com/watch?v=br7dalliJZk
« Last Edit: June 09, 2020, 10:56:09 PM by sirpedrosa »
By order of firing up:
Willw
« Reply #4 on: June 15, 2020, 01:16:59 AM »
Here is a PH2A that I did a job on some years ago.
https://www.youtube.com/watch?v=9lmmtqb74B4
6/1 clone standby generator.
Too many projects.
