Author Topic: Lister LD2-newcomer  (Read 3843 times)
Willw
Re: Lister LD2-newcomer
« Reply #15 on: June 06, 2020, 05:06:02 PM »
Welcome aboard Andrew079, in the meantime you could try the LR2 manual. My understanding is the LD is the predecessor to the LR, and very similar, if not identical engines.
You start here or elsewhere https://www.agrimanuals.com/lister-engine-manuals-374-c.asp
Note that these are not Workshop manuals, but if you inquire they might havew those as well.
6/1 clone standby generator.
Too many projects.
Andrew709
« Reply #16 on: June 06, 2020, 06:27:14 PM »
Very many thanks. I will look them up. In the meantime I ordered a 10thou oversized pistons from S and H. Slightly shocked at the price, but there we i go suppose. There is direction in the instruction book on the orientation of the barrels - straight fins towards flywheel and gears. Missed that first time round.
sirpedrosa
« Reply #17 on: June 07, 2020, 09:47:19 PM »
By order of firing up:
