Author Topic: My dodgy spill timing  (Read 2786 times)
Sam Lawrence
« on: May 21, 2020, 02:13:18 PM »
Hi. So I marked tdc on the flywheel (6.1) and then pulled the injector and used an old line to fire it at the flywheel. It fires about 2" after tdc, ie the injector mark is nearer 11 o clock than 12, 12 being tdc. Shouldn't it be about 3" the other side of tdc though? Maybe this is why it is almost impossible to start, despite having a recon injector and seemingly enough compression? Thanks!
sirpedrosa
Re: My dodgy spill timing - GO HERE!
« Reply #1 on: May 21, 2020, 04:06:42 PM »
Hi Sam
go here to see the injector timing! https://listerengine.com/smf/index.php?topic=8320.msg102965#msg102965
BR
VP
« Last Edit: May 21, 2020, 04:21:10 PM by sirpedrosa »
By order:
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Lister CD [355399] 1937 - on the bench..
Sam Lawrence
« Reply #2 on: May 29, 2020, 08:06:51 PM »
I'll have a look on the pc but on here that thread is even more confusing than the manual!
