Author Topic: Bad vibrations  (Read 1804 times)
RichardsSR2
Bad vibrations
« on: May 09, 2020, 05:04:06 PM »
Hello everyone. Just joined. My SR2 sits in my narrowboat in Parbold on the Leeds/Liverpool. It's had work done on the top end and starts well. The problem is it vibrates a lot and being fastened tightly to the chassis it vibrates everything else too. the vibrations even out at certain revs and are more pronounced at others. Is this a characteristic or a fault somewhere. Your opinions will be eagerly received.
sirpedrosa
Re: Bad vibrations
« Reply #1 on: May 09, 2020, 09:34:29 PM »
Hi Richards
How many hours work it has?
Prepare new bigend shells to fit!
BR
VP
By order of firing up:
Lister CD, [355399] 1937 - on the bench...
