CS oil control ring
(1/1)
Mickye:
Hello members I have a small problem I managed to break my 5-1 oil control ring on reassembly, it was a 10thou oversize. I was thinking of using a spare std size oil control ring instead of buying a new set do you think it would work ok as I'm worried if I bought a new set I would break another and waste £30+. I was thinking a small gap wouldn't harm the compression as its slotted anyhow. What are your thoughts please? Regards, Mick.
broncodriver99:
Hello Mickye. The oversized oil control ring is available separately. In the drop down menu where it says type there is an option to select the scraper ring only for £8.
https://www.stationaryengineparts.com/Non-Genuine-Lister-CS-Piston-Ring-Set-4.5-Inch-0.010-Oversize.html
Mickye:
Well I never! Thanks for that broncodriver99 i've looked on there plenty of times and didn't notice that single ring listed. Now I can get back to it and order one straight away. Thanks for your help.
