Author Topic: Intermittent starting  (Read 1179 times)
Welding
« on: April 26, 2020, 08:33:36 PM »
Hi all, I've had a few Lister d engines however this one has me struggling, it starts intermittent and usually only runs with butterfly closed, also cuts out if I move the needle clockwise , any help welcomed thanks
Re: Intermittent starting
« Reply #1 on: April 27, 2020, 07:20:40 AM »
I guess moving the needle clockwise is closing it - leaner?
And if "closing the butterfly" is the same as "choke" - then that is effectively richening it up, too
Which suggests it's starving?  Are all the orifices clean?  That would be my first check, fwiw
