Author Topic: Where do I start?  (Read 7252 times)
trickn7474
Where do I start?
« on: August 11, 2006, 03:47:57 AM »
I am new here, I have a Changfa 1115 on the way. I need to match it to a genhead. I don't know where to start. Who has good sets, what should I look for?
Re: Where do I start?
« Reply #1 on: August 11, 2006, 04:46:27 AM »
my vote is for a ST10 or 12 kwatt
i am sure there will be folks to point you where they are available
what all are you trying to do with it?  120/240 ac,,, drive anything else? compressors, alternators? pumps?
trickn7474
« Reply #2 on: August 11, 2006, 05:01:46 AM »
I live in South Mississippi, after Katrina I want something better than a gas generator. I have a good supply of waste veggie oil and waste motor oil.
« Reply #3 on: August 11, 2006, 05:48:51 AM »
well the changfa will run happily on a 50/50 mix of well filtered motor oil and diesel, a bit harder to start but comes up to temp and runs very well at that level.
i would probably recommend a belt drive running the engine at 1500 rpm or so,, they seem to be a bit quieter and smoother at that rpm.
your going to need a better and larger pulley than the one supplied with the engine to over drive the gen head to 1800 in my opinion
check ebay for the st heads
http://cgi.ebay.com/12-KW-GENERATOR-HEAD-end-gas-diesel-alternator-ST_W0QQitemZ180016213625QQihZ008QQcategoryZ42907QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or from this guy,,, i have dealt with him and he is a good guy
http://cgi.ebay.com/NEW-HD-24-KW-GENERATOR-HEAD-END-DIESEL-GAS-NR_W0QQitemZ110018204683QQihZ001QQcategoryZ106437QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i am sure there are other suppliers closer to you.
also check out
www.utterpower.com
george has alot of info on the changfa and the ST heads on his site
he also has some cool upgrade parts for the changfa engines, such as water manifolds and tstats, drive pulleys, and all sorts of other stuff.. great guy
gpkull
« Reply #5 on: August 12, 2006, 10:49:23 PM »
trickn you might consider getting i touch with mike m  listeroidusa he had st heads available my dad got a 10k not to long ago from him. also he does a fantastic job making pulleys. the diameters for my 24/2 and my dads 12/1 where different but he had the pulleys right on the money the ones we got from him were sk bushing type
