Author Topic: gasket for the 6/1 - which side up?  (Read 4425 times)
tyssniffen
« on: February 21, 2020, 03:01:37 AM »
So, this seems like a really dumb, but really important question, if in fact it does matter.
I'm looking at a brand new copper gasket for my 6/1, and there's a slight difference between the sides.  One side has a bit of a ridge:
and the other side seems completely smooth:
Which side should face the sky, if it matters?
« Last Edit: February 21, 2020, 03:03:34 AM by tyssniffen »
Re: gasket for the 6/1 - which side up?
« Reply #1 on: February 21, 2020, 05:47:15 AM »
A copper gasket is just a thin sheet of copper.  Your pic seems to show some thick material in the middle ?
I think the consensus is that this style leaks easily, and that the style with RTV sealer around each hole and a crimped on fire ring for the cylinder, holds up well.
So I don't know which side goes up.
sirpedrosa
« Reply #2 on: February 21, 2020, 08:40:55 AM »
Hi tyssniffen
Just look at here: https://listerengine.com/smf/index.php?topic=8320.msg103752#msg103752
The original gaskets (and original Lister) has 2 large holes and guides to fit the gasket in correct way!
VP
By order of firing up:
tyssniffen
« Reply #3 on: February 21, 2020, 04:33:22 PM »
this is the style my machine came with, and what I've been told is the standard gasket.
Well, I've previously used this sort:
and had trouble with that as well.    I had one of those in place (perhaps not cranked down hard enough) but after sharing a photo of it, I got a lot of advice here https://listerengine.com/smf/index.php?topic=8711.msg101309#msg101309  that it was the WRONG type.   Thus, I went back to the smooth copper.
Sorry, but I don't see this showing *which side* of the copper goes up.  It's not the orientation, as the studs and holes force a specific sitting... it's which side is up and which side is down - that's the question.
sirpedrosa
« Reply #4 on: February 21, 2020, 05:50:33 PM »
Hi Tyss
Original ONLY can go one way.
And the side of the ridge stay faced down.
VP
« Last Edit: February 21, 2020, 05:53:26 PM by sirpedrosa »
tyssniffen
« Reply #5 on: February 22, 2020, 04:55:25 PM »
Hi Tyss
THIS is what I wanted to know.   The completely smooth side goes up, the side with the slight ridge goes down.
tyssniffen
« Reply #6 on: February 22, 2020, 04:56:25 PM »
As water seepage appears to be a problem on some Lister engines, It might be worth giving them a hit with this stuff. Isn't exactly cheap but seems to work well and truly as advertised in my experience.
I soaked my last one (perhaps put in the wrong way up??) with copper spray, and still had problems.  I will soak it again.
sirpedrosa
« Reply #7 on: February 22, 2020, 07:39:40 PM »
Hi Tyss
Hi Tyss
Have you seen my thread as I told you?
Here, again. Pay attention - PLEASE: https://listerengine.com/smf/index.php?topic=8320.msg103752#msg103752
What do you see? Honestly!
VP
tyssniffen
« Reply #8 on: February 22, 2020, 09:43:23 PM »
Well, if you’re really asking - I see 1 picture of a copper gasket- that looks like it goes to. A 12/2, with unique sized holes based on the stud bases... so I know that gasket isn’t the same as the one in my hand, so it’s impossible to know if that 12/2 had the same ridge as mine, making the whole post impossible to learn from.
sirpedrosa
« Reply #9 on: February 22, 2020, 11:32:19 PM »
Tyss
I give up, really...
sirpedrosa
« Reply #10 on: February 24, 2020, 08:20:14 AM »
Gentles
"The worst blind is the one who doesn't want to see", says a popular saying.
If the help didn't help, I gave the best help I have.
If it wasn't the best, I don't have another one. A different one, I just have a little prayer to ask wisdom to the lord.
Stay safe
VP
PS: By the way Bob (aka Ajaffa1) gave an interview asking for bricks and cement to help rebuilding his home, and others too. Maybe he got better opinion about that gasket.
« Last Edit: February 24, 2020, 08:22:41 AM by sirpedrosa »
« Reply #11 on: February 24, 2020, 09:13:14 PM »
Hi Tyss
I really don't think it matters, certainly not in these engines.
The ridge is there to provide an extra good seal between the cylinder barrel and the head, as it has to contain the combustion gases (it's called the fire ring). The rest of the gasket only has to hold back water. It's been a while since I looked at a Lister CS head, but IIRC it's basically completely flat, with holes for the combustion chamber and valves. So it'll squidge down extra hard around the ring whichever way up the ring is. It goes without saying, I hope, that both the top of the barrel and the face of the head must be absolutely spotlessly clean and smooth and flat to within a couple of thou (0.002"), otherwise you'll not make a good seal. There's no good reason not to use a little gasket sealant around the waterways, just make sure you go the right side of the bolts...
Interesting thread here: https://www.fordbarn.com/forum/showthread.php?p=76638
Apparently the fire ring can, in fact, indent the head (although that being a Ford forum, I don't know if they're talking about aluminium or cast iron), their recommendation is fire ring up, because it's easier to resurface the head if it gets dented. Probably also true of a Lister; but also, probably not a problem for a 6hp lazy diesel.
Of course, if one had a 12/2, one could do the experiment by installing the gaskets opposite ways up on each cylinder, and trying it out. Should anyone wish to ship me a 12/2, I will sacrifice the time to do the experiment, in the interests of science, obviously :)
sirpedrosa
Re: gasket for the 6/1 - which side up? - FWIW
« Reply #12 on: February 24, 2020, 10:54:29 PM »
Gentles
FWIW - cylinder head gaskets of original CS Lister (single or twin [2xsingle]) ONLY can go one way - because there are no symmetrical faces, unless you open new guide holes
VP
tyssniffen
« Reply #13 on: February 28, 2020, 04:50:15 PM »
the next time I have a 12/2 all boxed up and no where to go, I'll send it your way.
Are you saying - giving me permission - to use extra make-a-gasket sort of material around the holes, IN ADDITION to the copper spray stuff on the copper gasket?
Hugh Conway
« Reply #14 on: February 28, 2020, 09:17:54 PM »
Re: the "sandwich" gaskets........thin copper, a paper filler, another thin copper, as the Indian listeroid gaskets.
Back in the earlier days of this forum, it was suggested to soak the gasket in a liquid floor wax with silicone. the paper like material soaks up the silicone, making it waterproof. Otherwise coolant eventually wicks through the paper. Let the gasket dry out dry before installing.
Works for me. I have used the composite gaskets too. They seemed to work great on my Dursley, but the somewhat different listeroid head does not give good results. In fact, GasketNation recommended their Lister head gaskets be used only on original Listers, or clones that are copies of the original head bold pattern.
Hugh
1963 BMW R-27 project
