Author Topic: injector pump  (Read 2032 times)
vegoil
injector pump
« on: February 13, 2020, 10:35:36 PM »
Is this a good way to set the pump timing? ( see the youtube video) It looks very good to me.
how far advanced do you recommend for running a Lister cs 8/1 on straight veg oil?
https://www.youtube.com/watch?v=qEeGJuNAyCM
John
vegoil
Re: injector pump
« Reply #1 on: February 14, 2020, 03:33:45 PM »
has anyone tried this method of timing?
is this the same as the spill method and is the first spot of fuel on the flywheel meant to line up with the zigzag injector mark on the flywheel. for veg oil another 5*
What do any of you think?
Re: injector pump
« Reply #2 on: February 14, 2020, 11:45:04 PM »
That method of timing looks about right.
Give it a try.
You will have to find a way to mark your flywheel at approx 20 deg BTC and then adjust your initial spray point to either side of that mark depending on the engine specs and the fuel being used.
vegoil
Re: injector pump
« Reply #3 on: February 15, 2020, 08:29:47 AM »
The fuel that I use is Clean used cooking oil
vegoil
Re: injector pump
« Reply #4 on: February 16, 2020, 01:24:51 PM »
I am running on wvo only The engine and 1200 litres oil are in the same building its well insulated so the temperature is around 35*c summer and winter I do not thin the oil other than the temperature of the building the engine runs for 14 hours a day with 1 hour gaps as all the heat goes into storage heaters.
I am just looking to get the original 1959 Lister CS 8/1 to run to its most efficient?
Re: injector pump
« Reply #5 on: February 20, 2020, 02:50:41 PM »
Edit: Oops, replied to the wrong thread  :-\  I moved it here ... "Water Steam Injection"
https://listerengine.com/smf/index.php?topic=8949.new#new
It's unlikely that you will need water injection on a continuous basis so consider an algorithm to intermittently dose the engine.
You may already be aware, but the arduino "uno" and "mega"do not have WiFi capability.
If you wish to communicate with the system from the house, take a look at the Wemos D1R2.
Form factor and programming language is the same as Arduino but it has WiFi connectivity.
It even uses the Arduino programming software.
Costs around $10
The big difference with the Wemos is that it's pins are all 3.3vdc (like the raspberry Pi) unlike the Arduino which is 5vdc.
Buy local from Amazon. (As you know, ... EBay is not shipping from the Asia at the moment)
Make sure it's the Wemos D1 R2 . The older Wemos D1 has been phased out but there may still be some old inventory being sold.
cheers,
« Last Edit: February 20, 2020, 03:01:01 PM by veggie »
