Author Topic: Inverter question - Resistive loads  (Read 1119 times)
« on: January 15, 2020, 04:59:45 PM »
Can I run an emersion heater from an inverter? or is this bad for the FET's ?
I have a DC system with a small diesel to keep it charged and it can run when loads are applied also.
The DC alternator is rated 140 amps and should be able to keep up to a 1.5kw drain.
How do mod-sine wave and pure sine wave inverters react to resistive loads.?
In this case, a 4KW, 120 volt inverter and a 1.5 kw, 120 volt heating element.
Re: Inverter question - Resistive loads
« Reply #1 on: January 15, 2020, 05:04:14 PM »
What an interesting question.  We're grid tied so from 9:00 AM to 3:00 PM I would think our SMA 6 KW 240 volt inverter carries our electric hot water tank most days.  Ignorance can be a beautiful thing.
Hugh Conway
« Reply #2 on: January 15, 2020, 06:18:43 PM »
Veggie: I have run a heat gun, mu wife using an electric iron for a few minutes using my battery bank and inverter (24V, 4000W) The inverter complains.
With the 6/1 turning the PMG (120/240V), and powering the heat gun, or an electric heater, it is fine
Hugh
1963 BMW R-27 project
« Reply #3 on: January 16, 2020, 03:50:02 AM »
Just because an alternator is rated at 140A, does not mean it's spinning at the right speed to generate 140A.
But yes, a immersion heater is a purely resistive load, and should not pose any problems for a mod sine or pure sine inverter, rated to deliver 130% of the load.
If your heater is 1500w, you inverter should be spec'd to about 2,000 w so it is less likely to over heat.
1500w is 125A, so that's a beefy load, and your battery/inverter cables need to be able to carry it without resistive losses.
« Reply #4 on: January 17, 2020, 01:25:09 AM »
Thanks, I am aware of that Mike90045.
It's a Leese Neville.
I have the factory performance curve showing speed vs. output vs. required HP.
Alternator speed and output are mapped to the engine speed and output.
It can make 120 amps if needed.
Glort: "Resistive loads are the easiest, gentlest loads you can have.  Anything will drive them happily. It's inductive and switching loads that pose the challenges. "
That's good to know about the resistive loads. Thanks.
Flywheel diameter and alternator pulley have all been worked out back when the unit was built.
« Last Edit: January 17, 2020, 07:32:21 PM by veggie »
« Reply #5 on: January 17, 2020, 07:30:45 PM »
You certainly have the right alt.
Do you have an external controller and are you running it at 12v or 24?
Looks like a nice setup.
This battery system is a small 400aH 12 volt bank.
At the moment I use the stock internal regulator for bulk charging and let solar do the float charging.
Certainly not as good as a Balmar external 3 step regulator or something like that.
I have not been able to find an external multi step regulator for under $300.
And when converted, that is over $400 Canadian.  :o
Has anyone seen a decent chinese external regulator?
« Last Edit: January 17, 2020, 07:33:55 PM by veggie »
« Reply #6 on: January 18, 2020, 02:24:12 AM »
Charging from a generator, you don't need 3 stage (or 2 stage) unless you are running unattended for long times. Set your bulk voltage and when the amps start to drop, you have started Absorb, for as long as you like.
