Author Topic: Listeroid Metro 6/1 TRB bearing.. Replace or run..  (Read 844 times)
Mtour
« on: December 01, 2019, 12:20:22 PM »
Hi
 Not sure if these bearings can be run in this condition, all the research I could come up with seems to point to that these bearings seldom fail.
 Run or replace.... Thanks..
« Last Edit: December 01, 2019, 12:39:25 PM by Mtour »
Re: Listeroid Metro 6/1 TRB bearing.. Replace or run..
« Reply #1 on: December 01, 2019, 09:42:50 PM »
Hi
Looks to me your bearing was installed with an improper preload
https://youtu.be/iQpgH7K2_t8
Mtour
« Reply #2 on: December 01, 2019, 10:23:33 PM »
Thanks for the reply..
 Could be, the crank would not rotate heavy side down without help. The piston, idler gear disconnected with the flywheels off.
32 coupe
  • "Doc Johnson" on call !
« Reply #3 on: December 02, 2019, 12:39:45 AM »
Check:
 1.  Bearing preload.....
2.   Then crank runout....
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
« Reply #4 on: December 02, 2019, 04:26:22 PM »
Those bearings are ruined and need to be replaced.
Should be some numbers embossed into the bearing parts, use those numbers to cross over to a known manufacture with a well earned reputation for quality.
Mtour
« Reply #5 on: December 02, 2019, 06:58:06 PM »
thanks...new bearings purchased..
