Can anyone identify this?
(1/2) > >>
guest23837:
I bought this old consaw it wont start, good spark and good compression I think it needs a carburettor. It's supposed to be a Husqvarna. Hoping one of you guys can identify it. thanks
photos are on dropbox link below
https://www.dropbox.com/sh/ah6v5if3fogof0y/AACBWqOOPlwlBbgf3lA7kMbka?dl=0
Willw:
Looks like a Dolmar 309 or similar
https://www.youtube.com/watch?v=8k4Df3wYjGA
guest23837:
--- Quote from: Willw on November 23, 2019, 05:01:39 PM ---Looks like a Dolmar 309 or similar
--- End quote ---
Fast response and on the money, thank you very much!
Willw:
Possibly a Dolmar 343, I am not familiar with these so do your comparisons.
https://www.propertyroom.com/l/dolmar-343-cut-off-saw/10940613
Willw:
Apparently the 309 and 343 might use the same carb, but check that the one you have is the same brand and part number as the kit.
Often times we get away with only changing the rubber metering diaphragm and adjusting the mixture screws; for which you possibly need a special tool.
https://www.ebay.com/itm/RK-27HS-CARBURETOR-REPAIR-KIT-DOLMAR-116-120-133-143-309-343-TILLOTSON-CARB-DR94/262211578884?hash=item3d0d072c04:g:Xr8AAOSw3KFWgBdS
