Author Topic: Four cylinder Lister Engine pair  (Read 3533 times)
« on: November 07, 2019, 12:08:17 AM »
If I had the funds I would add these to my collection.
« Last Edit: November 07, 2019, 12:10:42 AM by snowman18 »
Re: Four cylinder Lister Engine pair
« Reply #1 on: November 08, 2019, 09:57:21 PM »
If they were anywhere near me, they would be taking up their new residence in my shed for that price.
Canada is entering her snow season, its possible these will still be available in the spring. I'm considering month payments, after all he holds the trump card with possession.
I really do not need these but its a bloody disease having this affliction towards these wonderful diesel engines.
« Reply #2 on: November 08, 2019, 10:09:02 PM »
One of the projects I have on the go is building a still for essential oils and the maximize  the capacity of the stills boiler the branches need to be shredded.
I spent a bit of time researching those small gas powered chipper / shredders and came to the conclusion they're a joke.
Then I found and purchased this old silage chopper, it has a 40" diameter wheel with four blades and a powered conveyor to feed the chopper.
I later found and purchased a VG4D Wisconsin engine that I intend to use as power for this shredder but one of those four cylinder Lister engines would make my day.
« Last Edit: November 08, 2019, 10:15:01 PM by snowman18 »
« Reply #3 on: November 09, 2019, 05:14:13 AM »
glort how many KW you figure is attached to that one engine.
listard-jp2
« Reply #4 on: November 09, 2019, 07:25:26 PM »
/\ Be careful with those Glortismn like assumptions because whilst these engines will run to 2500 RPM, they would have to have had certain high speed options fitted from the outset, and without them, the life expectancy will be drastically reduced.
These engines are most likely a Lister SL4 engine, it could also be SR4 (it is difficult to tell exactly from the data plate).
Apart from a closer inspection of the data plate, the shape of the cylinder barrel finning will confirm it. The SL has a fin profile which follows the shape of the cylinder bore, ie more rounded.
The SR will have a finer pitch and the when looking from above the outline of the finning will be square.
If it is an SL (most likely) before buying, confirm these engines are good runners, and nothing critical is missing, as there are a lot of unique parts in an SL, and even more so in a four cylinder version.
These 4 cylinder engines are rare, and were typically used on grain dryer and marine applications.
Here is a marine version: https://www.ebay.co.uk/itm/Lister-SL4-20hp-4-cylinder-marine-diesel-engine-vintage-stationary-engine/333382378189
Here is an instruction manual for a SR4 grain dryer: https://www.ebay.co.uk/itm/Lister-Type-SR4-Air-Cooled-Diesel-Engine-Instructions-Parts-List-Book-1398-1068/202556892415
If it is anything else other than a good runner walk away, otherwise you could be having open wallet surgery thereafter.
Someone on here did document the restoration of one of these engine some time ago, and when he did so, he was lucky, as Sleeman and Hawken were on the knockings of the last of specialist parts he required (I know as I researched it for him, as you will see from the forum thread), see here:
https://listerengine.com/smf/index.php?topic=6174.0
« Last Edit: November 09, 2019, 07:38:54 PM by listard-jp2 »
« Reply #5 on: November 10, 2019, 03:03:58 AM »
It may be that 20-odd BHP won't run a 40" chipper?
I seem to remember maybe a 60kW motor on the timber chipper at the last mill I worked at?  Been a while, and I could easily be wrong?
Might be worth doing some homework first?
