Author Topic: Onan 9 MDKAV  (Read 6379 times)
Tanman
Onan 9 MDKAV
« on: November 02, 2019, 02:58:43 PM »
So I just unexpectedly won an online auction for an Onan 9kw MDKAV marine diesel genset. 1800rpm low hours 3 cylinder Kubota powered. However it needs a raw water supply to run, has anyone tried adapting something like this to stationary use? The inlet is only a 1” tube for the raw water intake this heat exchanges with a closed coolant system on the genset. Open to creative ideas and will post pictures once I go pick it up.
Kubota ea300
Metro 12/2
32 coupe
  • "Doc Johnson" on call !
Re: Onan 9 MDKAV
« Reply #1 on: November 02, 2019, 09:51:57 PM »
I have something similar and removed all the marine cooling and use a Honda radiator with a fan.
Works great. The radiator was purchased on Ebay for a few dollars. Aluminum racing part.
The exhaust manifold was replaced with one from a tractor that used the same engine.
When you have to buy the impeller for the raw water pump you will thank yourself.
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
Re: Onan 9 MDKAV
« Reply #2 on: November 03, 2019, 02:48:20 PM »
This is before I installed the exhaust manifold but you get the idea.
You can see I also used the ST type gen head.  It's an early one with good windings and stable voltage.
Most marine units are "ditched"  because the gen head goes bad.
« Last Edit: November 03, 2019, 02:54:59 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
Re: Onan 9 MDKAV
« Reply #3 on: November 04, 2019, 04:45:13 AM »
Thanks Glort,
That gen set has a Mitsubishi engine. I think a k3d. I have now install a custom fuel tank as well as gauges
and wiring. I'll try to post a pic tomorrow.
It has about 1000 hrs on it and I got it for nothing with a dead gen head and after checking the cost of a
rewind I decided to build this. I had the st head from another project.
I have a 2 cylinder that has a factory remote head with controls and gauges with only 50 hours but it too has
a bad gen head.  Been looking for a 5kw Stamford clone head for it.
So many projects and so little time.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
Re: Onan 9 MDKAV
« Reply #4 on: November 04, 2019, 09:05:03 PM »
Still needs a little more paint work but runs fine. It's been a project for several years now.
No point in getting in a hurry!
« Last Edit: November 04, 2019, 09:08:45 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
Tanman
Re: Onan 9 MDKAV
« Reply #5 on: November 05, 2019, 03:31:41 AM »
32 coupe, that is an awesome setup, I’ll post some pics of mine when I get it here. Glort , thanks for the tip I’ll start doing some digging see if I can find some common issues, would you mind asking your brother in law to see what his were and what happened?
« Last Edit: November 05, 2019, 04:39:05 AM by Tanman »
Kubota ea300
Metro 12/2
Tanman
Re: Onan 9 MDKAV
« Reply #6 on: November 13, 2019, 03:15:38 AM »
Got it home today, have to check a few things and hook up some fuel to test it out!
Kubota ea300
Metro 12/2
