Author Topic: Kubota EA300  (Read 55979 times)
Re: Kubota EA300
« Reply #30 on: June 17, 2022, 07:00:40 AM »
Not sure what a 'flux welder' s but if it is an arc welder always look at the inverter models. Same goes for a MIG.TIG,ARC welder. We live on the mid north coast of NSW and often get black outs for no apparent reason and only in half of our small village. This made me go out and buy a genset off fleabay and is a 5kw model. Big enough to keep our fridge and separate large freezer running in Summer.
Pookie
Re: Kubota EA300
« Reply #31 on: September 20, 2023, 12:46:50 AM »
Hello,
Have a Kubota EA 300 from an 18 wheeler APU.  It started and ran fine.  Changed the fuel filters and fuel pump now have problems getting it to start.  Seems as if starving for fuel.
Maybe air in line???           Should I crack the line at the injector and see if any air comes out???
Currently starts and runs a minute before shutting down.
Thoughts.     Thanks
Re: Kubota EA300
« Reply #32 on: September 24, 2023, 12:38:41 PM »
If bleeding the air out start from the tank first and work your way along at each joint. If you have a hand pump use it to bleed the system. Dont skip any part do the filters as well if any finishing at the top of the injectors. Then have another go at it
Apply
Re: Kubota EA300
« Reply #33 on: January 25, 2024, 11:58:20 AM »
About those Kubota EA300s you found for $300-$500, that sounds like an excellent price, especially if they're in good condition. Kubota tractors usually lasts a long time and works well.
I got myself a 2007 KUBOTA L3940HSTC tractor for around $29,500, a good deal. I needed a new engine and found a Kubota V2403 engine on this website. It cost me about $2,500, which was reasonable. This site has lots of different Kubota parts and tractors. You can check it.
« Last Edit: January 29, 2024, 07:35:15 AM by Apply »
