Author Topic: Yanmar chp  (Read 9044 times)
saba
Yanmar chp
« on: October 18, 2019, 02:22:34 AM »
By luck I have some time on my hands, I like to replace my 6-1 start o matic chp thats giving to much vibrations to use it indoors for one based on a yanmar TS 105.
Yanmar I bought I while ago as a genset 5 kw, to start with a good base I opened it for a quick peek inside. Turned out piston ran a bit hot, liner just needed some honing. To start off "new"I ordered new piston and liner with some gaskets from sunity taiwan. I think the set has nearly no running hours just lack of cooling water.
I scored a silent box for a small marine generator, brand new still in plastic, it should just fit snuck inside the box.
I like the lister 10 times better but it's like having a horse like a pet in your house, the yanmar more being like a hamster.
I'll try to post progress reports, it will not go fast due to more important stuff eating time.
I was pretty far with automation on the lister, arduino current measuring temperatures flow coolingwater. So hopefully I can just mount it to this one without to much trouble.
Need to think about some exhaust system with heat recovery absolute no noise and no dripping of condensing exhaust fumes at places you don't expect/want.
Thinking of putting the silent box on a raised frame and doing my exhaust 'scrubber'underneath.
I might need to order a new pully for the electromotor, it says 2400 revs max for the yanmar and that should give 1510 on the electromotor.
Yanmar has a throttle handle stop start run, I will replace it with a servo should also give me the ability to in/decrease power.
Electromotor is a dahlander two speed 1500 or 750. The tag plate was not there when I bought it but I think it is at least 8KW by the look at the size. The lister I always started on low revs and when it was running I would pop the breaker untill it reached 620rpm and then switch to the high rpm breaker.
If you 'drive'an electromotor you can use it as a generator.
For example if you read the tag and it says 3kw and 1470rpm, then when you dive it to 1530 you will generate 3kw.
To be continued,
Bernhard
Re: Yanmar chp
« Reply #1 on: October 18, 2019, 03:54:33 PM »
saba,
Interesting project. I am currently building the same thing using a Changfa 175. A physically smaller system than yours.
The Yanmar should run quite smooth since these engine types have internal counterbalance shafts.
Having an enclosure for the system will certainly help you get control of mechanical noise.
I have not yet found a robust throttle servo to drive with my Arduino controller. I have several plastic units from ebay (with metal gears) but I fear they may not be reliable enough. What unit do you use?
Veggie
« Last Edit: October 18, 2019, 04:03:40 PM by veggie »
saba
Re: Yanmar chp
« Reply #2 on: October 18, 2019, 10:17:36 PM »
DS3218MG
From Ali express it feels strong should pull 20kg. I haven't tried it yet  but I will.
Bernhard
saba
Re: Yanmar chp
« Reply #3 on: October 18, 2019, 10:22:13 PM »
I still need to figure out something nice looking and functional to pull the valve lifter. I see your blanking plate has a bit more mass then mine, bit afraid mine is to flimsy and will leak. Will post some more foto's later today.
Bernhard
Re: Yanmar chp
« Reply #4 on: October 18, 2019, 10:32:38 PM »
I used 3/8" (10mm) steel plate for the blanking plate.
This gave me enough material to cut pipe threads for the connections.
The pipe fittings screw right into the plate.
The inlet and outlet are different to facilitate convection.
-Outlet fitting takes water from the top of the water jacket (right at the blanking plate). The highest point.
-Water return connection has an extension below the plate which delivers cooler water to the bottom of the cooling chamber.
I intend to use an "open" system which is vented so I do not expect any pressure to build. A high temp switch is necessary to kill the engine if the temperature approaches dangerous levels due to a heat exchanger pump failure or a radiator fan failure.
Re: Yanmar chp
« Reply #5 on: October 18, 2019, 10:42:55 PM »
As I understand it, the over-speeding of an electric motor can certainly provide power BUT the run capacitors (ratings) must be tuned to the specific load for best power quality and performance. Once your system drifts away from the load "sweet spot" the capacitors no longer match the motor output. If you keep a constant load AND tune the capacitors you may be ok.
As glort stated, the name plate data may not reflect output capability.
I recently read an article where an electrical engineer was able to get 3kw from a 5kw motor when tuning the capacitors for a similar project.
He optimized his system for 2500 watts output.
If the load was dropped below 1800 watts the power factor went out the window. Very poor.
The power company adjusts thier massive capacitors on the fly at the power station to match loads, that's why Mains power is always optimized.
« Last Edit: October 18, 2019, 10:50:22 PM by veggie »
saba
Re: Yanmar chp
« Reply #6 on: October 19, 2019, 12:22:03 AM »
Ok for this reason I got a three fase connection at home, here in holland every house has 3 fases but mostly only one fase is connected. If you connect a 3 fase motor to the grid it wil run with slip so the more power you take off the motor the more slip you have.
If you run the motor without load it will run at 1497 rpm (guess), the more load the more slip rpm drops. But if you 'overspeed' the motor you start generating.
The stator with all the windings creates the rotating field and pulls along the simple steel rotor but if you drive the rotor you will push the field in the stator.
I spend a lot of time on this and to my recollection it was my own invention to find out later loads of guys were doing the same.
I used up more then a 1000 liters of fuel so I hope it worked......
Nice thing is you can start your engine with your generator...
Regards Bernhard
saba
Re: Yanmar chp
« Reply #7 on: October 19, 2019, 12:31:41 AM »
Ok to make it clear I am not using anything just a breaker to connect the motor to the net and instead of the motor driving something ... you just start driving the motor. Works like a dream.
Only thing if there is a power outage ....you need candles.
Super save, I think reasonably efficient and cheap plenty old motors for sale for scrap money.
saba
Re: Yanmar chp
« Reply #8 on: October 19, 2019, 12:32:10 PM »
Hey glort, I think electromotor is approx 8kw, it's two speed dahlander. I always started the lister with it so this should be a lot easier.
On paper it should be profitable, electricity I generate pays for the fuel and then the generated heat is the profit.
But it's a hobby gives you an excuse to play with engines, and gives you something to show people if some birthday visitors come over.
It doesn't matter if hobbies cost money, if you leave out all the costs apart from fuel you make money just don't count the rest...
Bernhard
Re: Yanmar chp
« Reply #9 on: October 19, 2019, 03:12:41 PM »
Does the Yanmar have a 12 volt electric starter motor?
I suggest trying the starter motor without the decompression lever activated before you start designing a decompression servo.
Many of the commercial applications for these engines (including marine applications) do not use the decompression lever when starting.
The 12 volt starter motor may be quite adequate to rotate through compression.
However, if you need to use the electric motor/generator to start the engine some experimentation may be needed to see if has adequate torque.
Re: Yanmar chp
« Reply #10 on: October 19, 2019, 03:31:29 PM »
I wonder if these generic fuel system solenoids would work for your decompression actuation.
They are fast acting and have a fairly good pull strength.
That way you don't have to use PWM signaling to drive a servo on the Arduino. Just use a digital pin to drive a solid state relay.
https://www.ebay.com/itm/1502-12C2U1B2S1A-Fuel-cutoff-solenoid-12V-Kubota-D1402-D1403-D1005-D1105/392399233893?hash=item5b5cd12365:g:KxIAAOSwKgZdY5wN
« Last Edit: October 19, 2019, 03:39:17 PM by veggie »
Re: Yanmar chp
« Reply #12 on: October 20, 2019, 01:18:36 AM »
Without question it's easier on the starter to decompress. But not necessary on some engines. Very necessary on others
https://www.youtube.com/watch?v=XV0swraaikg
Depends on the engine.
Cranking of the engine at 6:15 minute mark
https://www.youtube.com/watch?v=phjoeEld8ac
A big 195 start without decompression. My 195 was able to easily do this also.
https://www.youtube.com/watch?v=DVJelEpPtoE
« Last Edit: October 20, 2019, 01:38:15 AM by veggie »
saba
Re: Yanmar chp
« Reply #13 on: October 20, 2019, 02:41:44 PM »
The ts 105 is handcrank only, but fairly easy. About the fuel solenoid I was also thinking in the same direction. Thing is how to mount it looking a bit neat...from experience I know temporal mounts stay there for eternity.
Thanks for the suggestions and help'
Bernhard
saba
Re: Yanmar chp
« Reply #14 on: February 11, 2020, 01:03:56 AM »
Not much has happened since last time, not much time to be busy with it.  Managed to buy a pool heater as a exhaust heat recovery, and mounted it. Bought a new pully to bring down the revs to a better rpm. Been tearing down my lister cs som, what a nice beast each flywheel must be around 100kg. I really love this thing. But it's like keeping a horse in an apartment.
My cool cell motorroom still need to be torn down but I am a little reluctant with my sound damper box wich is full with soot. Will become a mess.
just yesterday I came across a genset a kubota ZB 400/500/600 with a 5kva . I know I should not be buying more stuff but it's in my home town. I made an offer of 250E guy wants 350E.
I haven't seen it yet only picture, looks like it's been outside under a plastic blanket for 5 years +.
Anyone knows these engines, its 3000rpm stuff not really my cup of tea but might be a good deal.
Regards Bernhard
