http://www.enidine.com/Airmounts.html These look promising! Heres a blurb
Enidine Incorporated offers an excellent vibration isolator with high lateral stability for those applications where vibration isolation is required for machinery or equipment with high centers-of-gravity. The Enidine Air Mount provides the solution for these types of applications, extending your industrial machinery’s life.
 With its heavy-walled construction and air-cushioned isolation, the Enidine Air Mount system will provide resiliency and prevent static deflection and permanent set/drift with your machinery. It also has neoprene padded top and bottom surfaces for soft interface with all connecting and supporting surfaces.
Typical applications for the Enidine Air Mount are as follows: air compressors, CMM machinery, most rotating industrial equipment, tools, fans, laundry and general machinery.
The Enidine Air Mount can be sized for a wide range of loads operating in a 15 – 140° F (-10 – 60° C) environment.
Check out the PDF tear sheet it's mid page on the left hand side.
They use these mounts for forge presses they should be more than enough for a listeroid.
Best wishes
