Author Topic: Diesel Heaters  (Read 2720 times)
Re: Diesel Heaters
« Reply #15 on: October 30, 2019, 05:06:03 PM »
Interesting
For many years I had VWs - owned maybe eight or ten in the years before we had cheap Japanese cars available here.  My ex-wife wrote off at least four of them . . .
The last was a '70 bus with a 3-litre V6 Ford Capri engine which fitted in the hole in the back just nicely
Great to drive, but when it finally did what every Ford V6 engine does and expired in a cloud of expensive oily steam I bought a Toyota and have continued to do so
350,000 miles is impresive
Re: Diesel Heaters
« Reply #16 on: October 30, 2019, 08:59:04 PM »
I bought my Westy July 2000, drove it one year with that miserable 54 hp engine, could not take it so I installed a 1966 Chevy Corvair 110 along with a 1965 Corvair 4 speed into it
My father has a wrecking yard that specialises in Subaru.
Every year Just down the road from him at the beach park they have a BIG VW festival on the long weekend. They get over 300  Cars.
That same weekend he will have a load of people Coming in asking about Subaru Motors for Conversions.  Most of them are totally Clueless and either ask or tell him, " They Just Drop in ".
Yeah, Right.
In all the years he has been there and the probably several Hundred people that have come in asking, Only ever sold 1 Motor even though he is pretty cheap on what he sells.
Why is it there are so many people whom want to ask all these questions and find out about things they have no money to actually do?
He also gets lots of people that break down Ringing or coming in looking for VW parts despite the subaru Signs. This year He put a sign right at the gate and half way across the driveway saying NO VW Parts.
Yep, 3 clowns came in asking for parts.... on Sunday when he was closed.
The response they got was not repeatable here!   :laugh:
They are not the only ones. Land rover lovers are another crowd that seem to think every wrecking yard will have a bunch of stuff they want  regardless of what brand they specialise in.
From what I have seen, these heaters would warm a small space like a Vehicle pretty quick and must run at minimal heat the majority of the time so as not to turn it into an oven.
5 KW is enough for a house. In a camper.... I think you could be too hot still in the Antarctic.
I was also thinking these would be great if you had a decent tent Like the Old 12x12's In winter.  Be one of the few tents in the camp ground and probably the warmest.
dax021
Re: Diesel Heaters
« Reply #17 on: November 03, 2019, 12:09:18 PM »
Ford V6 was a common conversion on the old Kombi's here in S. Africa too.  I eventually went another route and installed a Toyota 2CT in mine.  Went better for cheaper than ever before in it's life.  Gave it to my brother around this time and as far as I know it ended up rotting away in a field somewhere.  Pissed off doesn't come close.
Re: Diesel Heaters
« Reply #18 on: November 04, 2019, 04:19:01 AM »
That would have been a Brilliant Conversion!
Shame your brother didn't appreciate it.  Must have taken some doing to get that configuration Motor  in there!
Re: Diesel Heaters
« Reply #19 on: November 04, 2019, 07:27:41 AM »
I had a google and of course there are some vids.  They fit in the hole really well!  And it's an older Toyota (read bullet-proof if you maintain it) with good low-RPM torque.  What a good conversion!
Beats hell out of the just-waiting-to-explode Ford V6.  Only good thing about that was the acceleration from the combination of the low final drive ratio and the 90-odd HP
dax021
Re: Diesel Heaters
« Reply #20 on: November 05, 2019, 06:52:19 AM »
Actually it was very simple.  Bought a kit from one of the used engine importers, where I sourced the engine.  Came with engine mount adapters to fit the Kombi crossbar, new bell housing to suit kombi gearbox and Toy motor.  Used a radiator and piping from a newer (T3?) Kombi and made up a bull bar/radiator mount up front.  VW never brought out any of the old busses in a diesel version in S. Africa, the first were the new shape (T4?).  They did however have a T3 with an Audi 5 cyl engine, one of which I owned at the time of parting with my old bus.  Now this was an awesome Kombi, albeit rather heavy on fuel at 15Lt/100Km
Re: Diesel Heaters
« Reply #21 on: January 14, 2020, 12:51:10 AM »
More people testing these heaters on alternate fuel now.
Some interesting tests....
diesel/vegetable oil
https://www.youtube.com/watch?v=-bmELZaH6zQ
https://www.youtube.com/watch?v=qQDKRpyynS8
- Kubota Z482 - 4kw
Re: Diesel Heaters
« Reply #22 on: January 14, 2020, 12:59:24 AM »
- Kubota Z482 - 4kw
Re: Diesel Heaters
« Reply #23 on: January 14, 2020, 06:25:25 AM »
I have "spoken" to both those guys a number of times by email. The local guy reckons he has racked up some substantial hours on his on a 50% blend with no problems. He has one heating his home which was my thought.
The glow plug on these has the fuel trickled onto it which vaporises and then burns.
Knowing the amount of ash veg leaves behind, i am somewhat confounded how this works longer term. I would expect some buildup over time. I am still considering one of these as a fallback to my own converted spa heater. The automation would be a plus, the fuel would not. From what i have learnt from these guys it should be a simpe but careful matter of removing the GP and cleaning it if there is a problem.
I would try a diesel veg blend and depending on the outcome of that look at going with low or high conversion biodiesel which i could brew up much cheaper than i can buy diesel.
If a 50% blend was workable long term ( and it may be possible to add a bit of water injection) it would certainly lower the running cost. For me, even on diesel they should work out cheaper than electricty. Anything less than that would be a great bonus.
