Author Topic: Southern Cross ETB diesel engine  (Read 7092 times)
Re: Southern Cross ETB diesel engine
« Reply #90 on: May 12, 2019, 01:23:06 AM »
Hi mike, went to my local pump shop last week looking for gland packing. Asked the guy about springs and seals to fit old piston pumps, sadly the owner cleared out all his old stock recently. He only deals in centrifugal pumps now.
Bought myself some 40mm nylon round bar that I am going to Sikaflex to the face of the valves, I will then face them off in the lathe to give me a decent seal.
« Reply #91 on: May 12, 2019, 01:50:29 AM »
Interesting
Somewhere there will be a stash of that old shit - and the know-how.  In a small town I bet
Wouldn't surprise me if the seating "valves" want something softer than UMWHE type stuff?  But I don't really know why I think that.  My memory is of rubber valves around 40mm diameter with a full-width washer behind them - kinda like a penny washer - so ghey may have been designed to be both soft and rigid?
You'll figure it out
« Reply #92 on: May 12, 2019, 10:36:44 AM »
Hi Mike, I have one of the original washers, it`s past it`s useful life but appears to be a composite with two nylon faces with a softer fabric or rubber layer in between, presumably these were reversible. The original is around 3mm thick, my plan was to use 2mm of Sikaflex and 1mm of MDPE, hopefully the rubberized adhesive will provide enough of a cushion to stop any hammering. I guess I will just have to try it and see what happens.
Cockie
« Reply #93 on: November 07, 2019, 02:28:16 AM »
Bob,
Good to see you version of the cart, that's different having the front wheels inside the frame, I like the concept. I expect to take delivery of an ETB in the next week or so, it's coming over from Magnetic Island, where it was pumping water for domestic use. Do you have a photo of the completed project? I would love to see them as I intend to couple my ETB up to a IBC piston pump.
Dave
« Reply #94 on: November 07, 2019, 09:35:05 AM »
Hi Cockie, sadly I do not have photos of the completed engine as I have had a devil of a job finding any engineering company willing to fit a sleeve to the cylinder. I now have three cylinders and a cylinder head, for various engines, awaiting machine work in Alstonville NSW. They will cost me around $2,000! I would have done the job myself if I could find a milling machine at a sensible price.
If you need any advice with your rebuild please contact me. I have a few contacts for parts and etc. Once you receive your engine you should register it with the southern cross registry, they will email you a whole lot of information and a service manual. It`s a free service. Good luck
Cockie
« Reply #95 on: November 08, 2019, 03:03:40 AM »
Thanks Bob, Ian the SC register guy, is a fellow member of North Queensland Machinery Preservationists, yes he has a lot of information, on anything Southern Cross.
