My thoughts on this....
I try not to run detergent type multigrade oils in engines with a 'true' sump, ie splash lubed with a weir below the big end falling off into the sump proper. There may be an oil pump present, and as long as it picks up oil an inch or so or more above the bottom of the sump and returns it to the weir, fine and good.... this sump will accumulate most water and metal debris, which will settle to below the oil intake. If a modern detergent additive multigrade oil is used, water and debris becomes émulsified' for want of a better term, and remains in circulation with the oil - the modern oil is doing what it is designed to, keep the dirt in suspension until it hits the oil filter, where it can be removed... the water in suspension is handled differently, it is also held in suspension by the detergent, until the engine hits a temperature where it will start to cook off... Seldom does a lister or clone crankcase go above about 80C unless you work it hard for quite long...and then, certainly on my units, it takes a good bit of load to keep it there...
If you don't have an oil filter fitted and have a settling sump, non detergent oil is, in my opinion, the better option. If you do have an oil filter, use a detergent type oil. If you have neither a settling sump or a filter, either oil should be fine, but a more regular oil change would be in order...
As to multigrade or monograde...30W is my first choice, semitropical to tropical temperatures here... For easier starting in the frozen hells that some of you poor sods live in, well, a 10W50 or 20W40 would certainly make it a bit easier to crank in a snow blizzard...
Just my 5c worth...and probably not even worth that much anyway!
Ed
