Alternative fuels > Other Fuels
The next hairbrained Idea......
dax021:
Read something once about a farmer who used an old tractor tube connectected to the digester outlet. When it was full he rolled it to his house, connected it to his stove and plonked a couple of concrete lintels on it to give pressure
guest23837:
Do those little gas conversion kits for petrol engines on a certain auction site actually work? Will they work for both propane and butane? They are interesting because you can store the fuel for a long period without it going "off" like petrol does. I did see a video of a guy that connected the crankcase pipe to bottled gas on a generator or lawnmower I cant remember which. It was a bit of a Heath Robinson affair.
How long would it run on a 12kg tank of butane? Is it safe?
guest23837:
I think I will get that little adaptor glort I was going to buy one from the UK it's £50 but 2 day delivery that's under €20!. I will keep an eye out for a non runner honda or honda clone generator. It's usually a fcuked carburettor full of varnish that stops these little machines from running. I could have a cheap generator and if it doeskin work out it's a very small loss. Gas is 50% cheaper than petrol I read somewhere but that's not really the appeal it's the machine sitting for 6 months unused and firing right up. Much better than cleaning the jets on a carburettor by the light off a Tilley lamp!
guest23837:
Petrol here is €1.50+ per litre gas is about €25 for the small cylinder you would use in a gas heater so relatively cheap. thats with shopping around you can also pay €1.65 for petrol and €30 for the gas. There's no non runners for sale near me at the minute but I can wait. The website I was looking at that said gas was 50% cheaper was American and they were using mains gas I know that even in Ireland its way cheaper than bottled gas. It has to be worth a shot I think.
mike90045:
I think most of the automotive AC pumps, require lube oil in the line, and not a simple sump.
[*] Previous page
