Author Topic: PETTER - PAZ1 - New project  (Read 150843 times)
sirpedrosa
Re: PETTER - PAZ1 - New project - Kart almost done
« Reply #195 on: September 28, 2024, 08:46:21 PM »
Gentles
A few more work at the kart to the geny.
Things are coming up.
A few pic to the show.
Remember when I start prototyping this kart? see here https://listerengine.com/smf/index.php?topic=8333.msg104744#msg104744
Put engine on to see how things are sorting.
Featuring a mufller to be more silent.
VP
Ps: Ill put later pics of detail of front axcel spindle. Take a look of it tilting limit.
PS2: PLEASE ADEV, TURN OFF THE AUTO ROTATING OF PICS, SO WE CAN SEE THINGS WRIGHT.
« Last Edit: September 28, 2024, 08:50:16 PM by sirpedrosa »
By order:
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Lister CD [355399] 1937 - on the bench..
sirpedrosa
Re: PETTER - PAZ1 - New project - spindle detail
« Reply #196 on: October 06, 2024, 10:09:51 PM »
Gentles
Here are the detail of the front axis spindle.
A 16mm of core inside a rubber hose of OD 24mm.
VP
By order:
sirpedrosa
Re: PETTER - PAZ1 - New project - handle bar, belts and test run
« Reply #197 on: December 07, 2024, 06:09:01 PM »
Gentles,
Had been a while this thread is idling but not halted.
Pulleys in place and aligned, and belts stretch.
Handle bar is also in place too.
Gave it a run to see the voltage and it is at 250ish.
Needs more tweaking and got to sort out the muffler in order to silent it.
A few pics to showoff.
VP
By order:
sirpedrosa
« Reply #198 on: August 03, 2025, 11:54:24 PM »
Gentles,
Finally this 2 toys got their show. Last 11th thru 13th the FERIARTE, in my village, people had the pleasure to see this gems.
The alternator work as good as it is intended to be.
Some pics to showoff.
VP
PS: a vid to showoff: FEIRIARTE_2025
By order:
dax021
« Reply #199 on: August 06, 2025, 02:54:39 PM »
Wonderful restorations VP.  Did you run them at the show?
sirpedrosa
« Reply #200 on: August 08, 2025, 08:52:32 AM »
« Last Edit: August 08, 2025, 11:30:38 PM by sirpedrosa »
By order:
sirpedrosa
PETTER - PAZ1 - New project - Storm Kristin
« Reply #201 on: March 16, 2026, 08:35:40 PM »
Gentles,
Im back... again!
Long story short: from 28jan till 21feb no grid power... and only yesterday phone line and internet came alive again.
Got to fetch the PAZ1 with geny from down town up to village. It end up to make almost daily 12+ hours of energy.
Its logbook states 217h, and it goes for overhauling. It needs new cylinder shim, and new gasket at time gear case.
Some pics and a vid [https://drive.google.com/file/d/1RDUCIRZ-U1jiIOY2lxdU3Gn_u9MuQDQZ/view?usp=sharing] will show better than words.
VP
« Last Edit: March 16, 2026, 08:43:59 PM by sirpedrosa »
By order:
sirpedrosa
PETTER - PAZ1 - New project - Storm Kristin... more pics
« Reply #202 on: March 16, 2026, 08:45:02 PM »
more pics
PS: This PAZ1 (425xxxx) from 1979 left the show piece life to became a work horse those days.
« Last Edit: March 17, 2026, 09:10:34 AM by sirpedrosa »
By order:
