Author Topic: Resurrection of a Lister 12/2  (Read 90348 times)
sirpedrosa
Resurrection of a Lister 12/2 - timing fuel pumps
« Reply #240 on: November 16, 2019, 04:32:07 PM »
9 - start to unscrew the IP tappet bolt;
10 - align the line of the plunger with start injection line;
11 - detail of fine tunning;
12 - final course of the plunger (very important this clearence to not damage de IP);
« Last Edit: November 16, 2019, 11:08:06 PM by sirpedrosa »
By order of firing up:
sirpedrosa
Resurrection of a Lister 12/2 - timing left pump
« Reply #241 on: November 16, 2019, 10:55:00 PM »
13 - setting TDC, with 2 marks for centering comparator;
14 - setting mark in fly rim, and verifiing with comparator (pencil needing glasses to read scale);
15 - aling the line of the plunger with start injection line;
16 - detail of fine tunning;
« Last Edit: November 16, 2019, 11:10:05 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - water exit manifold T
« Reply #242 on: November 16, 2019, 10:57:24 PM »
Brass T came from lathe workshop.
sirpedrosa
Re: Resurrection of a Lister 12/2 - olives harvest
« Reply #243 on: November 18, 2019, 10:38:37 PM »
Hi All
One more day harvesting olives...almost done for this year.
6 trees gave round 140kg.
4 pics fore those like this kind of amusement.
1 - Net to collect olives.
2 - tree already clipped.
3 - tree view... literally! (upon tree)
4 - productivity.
« Reply #244 on: November 19, 2019, 01:26:34 PM »
Hi Sp
Nice work, nice photo's.
What do you do with the olives?
sirpedrosa
« Reply #245 on: November 19, 2019, 02:17:59 PM »
Hi Stef
Each 350 kg provides a complete olive paste press. I usually get 10% extra virgin olive oil. A few kgs are salted and preserved to serve as table "hors d'oeuvre".
« Last Edit: November 19, 2019, 06:21:02 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - Almost done
« Reply #246 on: November 20, 2019, 09:48:24 PM »
Hi Gentles
The beast is dressed. Only need to be bleeded and oil pump primed.
2 pics to amuse...
1 - Hot water manifold detail.
2 - general view.
« Last Edit: November 23, 2019, 03:07:07 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - primed and bleeded, ready to fire up
« Reply #247 on: November 21, 2019, 10:17:54 AM »
Hi Gentels
All baskets are empty, just left the old hose clamps.
It's ready to fire up...
pics:
1- basket;
2 - Do you remember my Braims oil can?
3 - And our friend syringe? Bleed is bleed, isn't it?
sirpedrosa
Lister 12/2 ALIVE - 21NOV2019
« Reply #248 on: November 21, 2019, 07:16:32 PM »
Hi my Friends
First of all I'd like to thanks to all of you, whom helped me to reach this mile stone.
THE LISTER IS ALIVE!
4 pics and the link to 2 vids starting cyl 1 and cyl 2.
Cylinder 1 starting: https://drive.google.com/file/d/19icG0EaDB67yH_wLljhglXsW1nyKESBo/view?usp=sharing
Cylinder 2 starting: https://drive.google.com/file/d/1mk67GVyECd4eY0EDzCZ4OsBGyU82oe-W/view?usp=sharing
Couldn't start both cylinder at same time, because I realised it was to much kinetic energy to that casters in order to run steady.
Next step: making trolley and cooling tank.
« Last Edit: November 21, 2019, 08:43:22 PM by sirpedrosa »
Willw
« Reply #249 on: November 21, 2019, 11:24:48 PM »
Congratulations on getting her running. Good job.
6/1 clone standby generator.
Too many projects.
saba
« Reply #250 on: November 23, 2019, 01:41:23 AM »
Congratulations, I can not wait for a 10 minute youtube video.
good job !
Bernhard
sirpedrosa
Resurrection of a Lister 12/2 - Temperature gauge
« Reply #251 on: November 29, 2019, 08:33:51 AM »
Hi All
A new temperature gauge with 1/2 BSP sleeve  for placing in the hot water manifold.
« Last Edit: December 01, 2019, 09:15:27 AM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - time to decorating
« Reply #252 on: November 30, 2019, 11:37:40 PM »
Hi Gentles
The greeny is getting fancy. Look at his temperature gauge!
A new toy for my ISEKI, 2nd hand box but condition new - a bargain, trully!
And after almost one month of rain, tangerine tree is heavy loaded.
Have a nice weekend.
sirpedrosa
Resurrection of a Lister 12/2 - valve tap arrived
« Reply #253 on: December 03, 2019, 02:07:06 PM »
Hi Gentles
Cooling system is getting shape.
Knife valve tap arrived... from UK.
« Last Edit: December 03, 2019, 02:08:58 PM by sirpedrosa »
sinna42
« Reply #254 on: December 05, 2019, 11:19:44 AM »
Hi Sirpedrosa,
In post #179 you had a couple of photos of the fretting damage caused by slightly loose flywheels, but there were no replies !
Were the sizes ok so that you could just refit the flywheels with a well tightened gib key ?
Or did you have the shafts built up & remachined ?
I've just removed one of my heavy SOM flywheels from my Lister 12-2 & have the same sort of damage.
Not measured actual sizes yet.
What do folk think about using Loctite to address this problem ?
I know that Listerdiesel used Loctite on one of the flywheels on his Ruston 1ZHR.
Jim
« Last Edit: December 05, 2019, 03:00:17 PM by sinna42 »
Lister CS 3/1 1938, Lister CS 3/1 1939, Lister H4 Pump, Coventry Victor AN4 Mk1 1944, Gardner 1L2 1962
