Author Topic: Resurrection of a Lister 12/2  (Read 242277 times)
sirpedrosa
Re: Resurrection of a Lister 12/2 - 9/16 parallel key needed
« Reply #180 on: July 17, 2019, 12:43:10 AM »
Hi Everyone
I need a parallel key to fit my Lister's poly. Can anyone give some help with link to supplier.
Thanks in advance.
By order:
Bernard 18A - 1968 (mama's water pump)
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Deutz MAH 914, 1952 - Zündfix and go (7Mai2023).
Petter A1 [1519575] 6May53 - Fire 15nov25
Lister CD [355399] 1937 - on the bench..
« Reply #181 on: July 17, 2019, 01:28:23 AM »
I need a parallel key to fit my Lister's poly?
Thanks in advance.
Translation  is bad there😀 try that once more please.
sirpedrosa
« Reply #182 on: July 17, 2019, 08:01:59 AM »
Hi Butch
Indeed... I do my best. Blame the google translator cause it doesn't get the context. And i'm improving every day!
Nothing better than a image... Here it goes.
By order:
« Reply #183 on: July 17, 2019, 11:00:14 AM »
What you are after is commonly called square key stock.  Here we can purchase it at any good hardware store or at the China tool store called Harbor Freight. If you don't have access to such places go to Ebay and buy it there.
sirpedrosa
« Reply #184 on: July 17, 2019, 01:40:55 PM »
Butch
I'm after a rectangular key 9/16*5/16*3".
I'll search more arround.
By order:
sirpedrosa
« Reply #185 on: July 17, 2019, 03:14:35 PM »
Hi Everyone
First coat is applied. It's getting pretty.
Ps: Nothing like some days off.
By order:
sirpedrosa
« Reply #186 on: July 27, 2019, 09:08:56 PM »
Hi Everyone
Just passing by to show flywheels and pulley, painted and preserved for the next stage of assembly.
The rims and pulley face have been varnished and are gorgeous.
After a few vacation days...
« Last Edit: July 28, 2019, 01:27:06 AM by sirpedrosa »
By order:
sirpedrosa
« Reply #187 on: July 31, 2019, 01:25:04 PM »
Hi Everyone
Meanwhile another water pump to restore, this time a British Gryphon, 15 years + (since last maintenance) inside the well.
Have a nice day.
« Last Edit: July 31, 2019, 02:12:36 PM by sirpedrosa »
By order:
sirpedrosa
« Reply #188 on: August 02, 2019, 02:28:30 PM »
Hi Everyone
Sump/block came down to prepare to paint.
112kg of British cast iron! casted on 24JUL57.
By order:
sirpedrosa
« Reply #189 on: August 05, 2019, 12:27:58 AM »
Hi Everyone
Just passing by to show some improvements:
Do you recognize this GRYPHON? Lets turn to the Lister again...
Passing taps to tune threads.
Block bottom has a coat of alu paint primary.
And it has a very specialized four hands crane with NASA's made design lift bar, and a custom trolley.
Do you remember of my hunting cat, instead of a dog?
By order:
« Reply #190 on: August 05, 2019, 10:48:50 AM »
That 12/2 will be a show piece when you get it done!
sirpedrosa
Re: Resurrection of a Lister 12/2 - to be continued
« Reply #191 on: August 05, 2019, 09:19:41 PM »
Hi Everyone
Butch, the 12/2 is intended to be just a show piece, as I said before, because it is village history preservation.
Gryphon pump is finishied, with it's original color;
And the 12/2 block is on my "Cat's" paint bench.
By order:
sirpedrosa
« Reply #192 on: August 09, 2019, 03:08:51 PM »
Hi Everyone
a few more hands of paint brush.
Nothing like a pic.
By order:
sirpedrosa
Re: Resurrection of a Lister 12/2 - non governor cam pin
« Reply #193 on: August 11, 2019, 06:00:57 PM »
Hi Everyone
And specially Butch, whom I request his opinion about my idea to put back the non governor cam pin.
As seen in pic I drilled the center pin, that I intend to thread and put a screw, after tapping the pin.
Feel free to make your point of view.
Ps: Anyone can tell the correct cam end float. I have 0,3mm. Is that ok?
« Last Edit: August 11, 2019, 06:06:04 PM by sirpedrosa »
By order:
sirpedrosa
« Reply #194 on: August 14, 2019, 12:27:33 AM »
Hi Everyone
12/2 is getting his decoration too... And beginning to fit bits to see if everything is going ok.
« Last Edit: August 14, 2019, 12:30:56 AM by sirpedrosa »
By order:
