Author Topic: Resurrection of a Lister 12/2  (Read 90784 times)
sirpedrosa
Resurrection of a Lister 12/2 - vesus a Hit&miss (the elefant and the ant)
« Reply #300 on: July 22, 2020, 12:17:29 AM »
Hi Gentles
While a real size one doesn't get into my Christmas sock, I amuse with a model. C'est la vie!
Just a pic and link to FB: https://www.facebook.com/valdemar.pedrosa/videos/pcb.3463399577024966/3194791720587920/?type=3&ifg=1&__tn__=HH-R&eid=ARDKOcuu74awyPS3UDLhMKqmR8q7bUx7Z6NceVsEjXONBn7VyL7-aBVgaIyHc2RJqpz4ORMSbYYQi2Fp
Stay safe
VP
« Last Edit: July 22, 2020, 09:27:26 AM by sirpedrosa »
By order of firing up:
sirpedrosa
« Reply #302 on: July 22, 2020, 08:52:36 AM »
Hi Mike
Its all ok, but here goes link only for video: https://www.facebook.com/valdemar.pedrosa/videos/3194791720587920/?t=1
It is published in Stationary Engine Enthusiasts - a private group.
Stay safe
VP
« Last Edit: July 22, 2020, 09:27:40 AM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - Usefull reading
« Reply #303 on: August 14, 2020, 10:18:46 PM »
Hi Gentles
While surfing around internet, landed in a usefull site, that teaches basic and advance of mechanics and other info.
Take a look: http://constructionmanuals.tpub.com/
VP
sirpedrosa
Resurrection of a Lister 12/2 - Idle but not stalled
« Reply #304 on: September 01, 2020, 09:19:31 PM »
Hi Gentles
While the 12/2 does not have a proper cart, and his cooling tank, and the daily fuel tank in order, I am after a gem called Bamford SD4, take a look here: https://listerengine.com/smf/index.php?topic=9121.msg105551#msg105551
Lets see if this one get a mate by it!
VP
sirpedrosa
Resurrection of a Lister 12/2 - SOME NEWS ON THREAD
« Reply #305 on: December 03, 2020, 12:18:40 AM »
Hi Gentles
It has been a while this thread is idleing, and nothing like to post some news:
2 daily fuel tanks to get repaired.
A Lister DK (1950), that is advertised at 1000€ (thousand!), with some play in main bushing, to make it jump. (Was the first I saw here in running condition). Owner think it is made of solide gold!
And a surprise in my 12/2, with a loose gibkey in fly wheel.
Some pics to showoff.
Stay safe.
VP
« Last Edit: December 03, 2020, 12:24:01 AM by sirpedrosa »
sirpedrosa
« Reply #306 on: December 03, 2020, 12:22:06 AM »
more pics...
« Last Edit: December 03, 2020, 12:26:14 AM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - FUEL TANKS DONE!
« Reply #307 on: December 07, 2020, 02:25:23 PM »
Hi Gentles
Things are going slowly... but they will go.
Fuel tanks (original from 12/2, and a spare one waiting for another project that appears in the meantime with a CS engine.
Please stay safe, and give your opinion (good or not, it doesnt matter). What really matters is being around here!
VP
« Reply #308 on: December 07, 2020, 05:47:41 PM »
In case you weren't aware (you probably are?); the one on the right should have a chain going through that pulley to a float on the inside, and a bobweight on the outside. The higher up the side of the tank it goes, the less fuel you have...
sirpedrosa
Resurrection of a Lister 12/2 - Chain and float of fuel tank stollen
« Reply #309 on: December 07, 2020, 07:00:45 PM »
Hi AdeV
Yes, Im aware, and I got to make something alike. Chain and float were brass, so thief take it a long ago.
VP
Re: Resurrection of a Lister 12/2 - Chain and float of fuel tank stollen
« Reply #310 on: December 07, 2020, 07:18:15 PM »
Hi AdeV
I was fairly certain you'd know ;)
If you need pictures, both weight & float are present on my tank, so just let me know.
sirpedrosa
Resurrection of a Lister 12/2 - Fly in place again!
« Reply #311 on: December 07, 2020, 09:43:31 PM »
Hi Gentles
AdeV, please send pics, mesures and weight. And thanks in advance.
Fly is on place again. Gibkey (forgot to make initial pics) had 2 hight spots, and I gave it a slight file pass.
Crank against the wall, with MDF wood, to hold mallet tapping (to avoid damage in babbit).
Stay safe.
VP
Re: Resurrection of a Lister 12/2 - Fly in place again!
« Reply #312 on: December 08, 2020, 10:08:57 AM »
Will do - I'll try to get it done today or tomorrow, got to find it first!
sirpedrosa
Resurrection of a Lister 12/2 - "New" Stand Drill
« Reply #313 on: December 13, 2020, 01:14:59 PM »
Hi Gentles
"New" Stand drill bought to my bench!
30 minuts after arriving it lays disassembled on floor in bits, to clean and see how much money to put more on it. (off course could get a brand new one, but have no funny tearing apart a brand new one!)
Summary: new belts, all bearings (once its all apart), new return coil, repair thread of spin arbor retainer. And already ordered key and keyless B16 chucks, coil.
Some parts already with one coat of ruststop.
Ill make a bench with threaded rods to itself. Some pics for those doesnt like to read!
Stay safe
VP
« Last Edit: December 13, 2020, 01:18:46 PM by sirpedrosa »
sirpedrosa
« Reply #314 on: December 15, 2020, 04:52:20 PM »
Hi Gentles
New (expensive) set of bearings for drill;
AdeV,
Found suitable chain (square... guess from where?), and outside indicator for float (was a lever from an oil drum old tap) that will be turned to small dimensions.
A few pics to joy.
VP
« Last Edit: December 15, 2020, 08:34:13 PM by sirpedrosa »
