Author Topic: Resurrection of a Lister 12/2  (Read 24641 times)
sirpedrosa
  • 21NOV2019 - Finally I hear that sound
Re: Resurrection of a Lister 12/2 - Torque wrench snap locknut
« Reply #270 on: December 23, 2019, 09:57:08 PM »
Hi Gentles
After much argument with brand representative, today came the answer that the locknut has arrived, but also had the solution in sight...
Who doesn't has a dog, hunts with the cat ...
Merry Christmas everyone
VP
Lister 12/2 - 12651227
vdubnut62
« Reply #271 on: December 24, 2019, 01:55:35 AM »
Sirpedrosa,
    It seem that you are a very lucky man indeed!  In more ways than one.  A very Merry Christmas to you and your's and a Happy New Year.
Ron.
sirpedrosa
« Reply #272 on: December 24, 2019, 06:10:35 PM »
Hi Ron
I try to do my best, with the few means I have.
I wish the same to you and your home crew, and friends.
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - Relieve stress
« Reply #273 on: January 10, 2020, 07:40:40 PM »
Hi Gentles
Winter goes calm, the project of projects is finished (only the cooling tank and the proper kart are missing).
A few more occasional repairs: to another electric pump, give the old man's compressor a good overhaul, restore (if it can be) a dynastarter.
There is also a half-stopped project, let's see it gets somewhere, or just for scrap - for now it only spents my time, some oil retainers, a few ball bearings and special screws. At least I made a new tool for putting valve collets.
A few pics maybe give a better idea.
VP
sirpedrosa
« Reply #274 on: January 10, 2020, 07:43:02 PM »
a few more...
« Last Edit: January 10, 2020, 07:46:35 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - on Youtube
« Reply #275 on: January 12, 2020, 11:11:56 PM »
Hi Gentles
Here is a 5 minutes run on youtube: https://youtu.be/lCRhRxQKBAw
Have a nive week.
VP
« Last Edit: January 12, 2020, 11:17:04 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - Late Christmas
« Reply #276 on: January 16, 2020, 09:44:59 PM »
Hi Gentles
Just passing by to show my hex bit socket set that lands in my shoe, to use in my late project.
Stay safe
VP
sirpedrosa
Resurrection of a Lister 12/2 - Torque wrenches certified
« Reply #277 on: January 25, 2020, 12:04:58 AM »
Hi Gentles
Remember my torque wrenches? The big one has its new locknut, and the small was out of spec.
Both taken to the metrology Lab of ISQ (see: https://www.isq.pt/EN/services/metrology/) and certified (see seals).
This Lab is internationally renowned.
Be safe.
VP
« Last Edit: January 25, 2020, 12:09:23 AM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - Another step in new project
« Reply #278 on: February 02, 2020, 12:08:55 AM »
Hi Gentles
New project is going. Today making the camshaft extention to fit starting handle. Made also the dog and weld it to an adapted crank.
2 pic for the enthusiasts.
VP
PS: now it only needs a steel spring pin.
« Last Edit: February 02, 2020, 03:59:01 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - One head gasket to south, maybe!
« Reply #279 on: February 04, 2020, 10:31:57 PM »
Hi Gentles
Today I was maintaining the Lister. I filled the cylinder jackets with water, and when it started to work he splashed some water through the hot water outlet manifold.
I suspect that one of the head gaskets must be leaking. A few more hours to take the heads apart.
Nothing that a Lister can't be worth.
Anyway, TLC.
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - cyl #2 low spot leaking
« Reply #280 on: February 05, 2020, 07:45:19 PM »
Hi Gentles
The two heads are out and cleaned. A eye ball magnifier shows cyl # 2 was leaking due to a low spot.
Do you remember I didn't skim the cylindres, because I don't want to loss original stamps in the cast iron.
I think that just a retorque of studs will do, but in this way I can get the global picture of the work done before.
Now will get copper gasket seal to fill that little spot, and torque nuts to proper spec.
VP
Pics:
#1 refer to cylinder 1
#2 refer to cyl 2
« Last Edit: February 05, 2020, 07:55:10 PM by sirpedrosa »
sirpedrosa
« Reply #281 on: February 05, 2020, 07:47:39 PM »
Now pics from cyl #2
sirpedrosa
Re: Resurrection of a Lister 12/2 - copper gasket applied, and heads in place
« Reply #282 on: February 06, 2020, 05:55:49 PM »
Hi Gentles
Copper gasket applied in both bottom face of gaskets, because the face of heads has been skimmed and so they are perfectly flat.
Heads already in place and torqued, and I forget to make a pic of the coated gaskets.
Next start up of it iŽll let it warm up a bit to retorque all nuts, while it stays warm after shutdown.
VP
PS: 1 pic of the product.
« Last Edit: February 06, 2020, 05:57:41 PM by sirpedrosa »
sirpedrosa
Re: Resurrection of a Lister 12/2 - Engine log book
« Reply #283 on: February 16, 2020, 12:38:01 AM »
Hi Gentles
Engine log book for all rebuilded engines.
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - Elsa and Fabien put the shack down
« Reply #284 on: February 17, 2020, 10:06:34 PM »
Hi Gentles
Remember I said that the shack where the Lister was could not take another winter?
Storms Elsa and Fabian broke the roof of the shack.
2 pics from before and after.
VP
PS: on the right below you can see the lister foundation.
« Last Edit: February 17, 2020, 10:08:17 PM by sirpedrosa »
