Author Topic: Resurrection of a Lister 12/2  (Read 27820 times)
sirpedrosa
  • 21NOV2019 - Finally I hear that sound
Resurrection of a Lister 12/2 - pig tail
« Reply #240 on: November 03, 2019, 03:48:23 PM »
Hi All
All projects are idling (duty far from them), but not fully stopped.
Pig tail is in place. Small bits come slowly from basket, but they will get their place...
VP
Lister 12/2 - 12651227
sirpedrosa
Re: Resurrection of a Lister 12/2 - Updating
« Reply #241 on: November 04, 2019, 12:11:26 AM »
A few more bits in place.
Injection pipes getting straightened, and water manifolds in place to planning hosing.
Have a good week.
VP
sirpedrosa
Resurrection of a Lister 12/2 - Brass parts for cooling circuit
« Reply #242 on: November 04, 2019, 11:01:06 PM »
What about this idea for cooling circuit?
It only needs the valve gate tap.
PS: I managed to get an old stock faucet to make drain tap.
« Last Edit: November 04, 2019, 11:08:30 PM by sirpedrosa »
sinna42
« Reply #243 on: November 13, 2019, 04:23:34 PM »
Excellent thread ! I've just acquired a Lister CS 12-2 Generator set & am busy stripping down the engine at the moment.
So this thread is of great interest !
Jim
Lister CS 3/1 1938, Lister CS 3/1 1939, Lister H4 Pump, Coventry Victor AN4 Mk1 1944, Gardner 1L2 1962
sirpedrosa
Resurrection of a Lister 12/2 - fuel pump timimg with comparator
« Reply #244 on: November 16, 2019, 04:21:43 PM »
Hi my friends
Today (after 400km) is time to give some TLC to the beast!
Timing injection pumps: pics by order...
1 - setting the probe to the comparator (nothing like a strip of duct tape). This probe - I think - NASA's will never get an ideia of it's origin - ok I disclose, it's a stell strip that holds the visel rubber of a wind shild wiper.
2 - setting the magnetic base of the comparator in place;
3 - setting the magnetic mark in filter to align with the fly rim;
4 - setting the TDC in the comparator;
sirpedrosa
Resurrection of a Lister 12/2 - timing fuel pumps
« Reply #245 on: November 16, 2019, 04:27:05 PM »
5 - mark the TDC in the fly rim;
6 - manual spec by Peter Forbes (RIP)
7 - mark -4.25" = 20 BTDC in the fly rim;
8 - reading the comparator value in mm = 4.25" = 20BTDC = -5,25mm BTDC (stroke);
« Last Edit: November 23, 2019, 03:02:18 PM by sirpedrosa »
sirpedrosa
« Reply #246 on: November 16, 2019, 04:32:07 PM »
9 - start to unscrew the IP tappet bolt;
10 - align the line of the plunger with start injection line;
11 - detail of fine tunning;
12 - final course of the plunger (very important this clearence to not damage de IP);
« Last Edit: November 16, 2019, 11:08:06 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - timing left pump
« Reply #247 on: November 16, 2019, 10:55:00 PM »
13 - setting TDC, with 2 marks for centering comparator;
14 - setting mark in fly rim, and verifiing with comparator (pencil needing glasses to read scale);
15 - aling the line of the plunger with start injection line;
16 - detail of fine tunning;
« Last Edit: November 16, 2019, 11:10:05 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - water exit manifold T
« Reply #248 on: November 16, 2019, 10:57:24 PM »
Brass T came from lathe workshop.
sirpedrosa
Re: Resurrection of a Lister 12/2 - olives harvest
« Reply #249 on: November 18, 2019, 10:38:37 PM »
Hi All
One more day harvesting olives...almost done for this year.
6 trees gave round 140kg.
4 pics fore those like this kind of amusement.
VP
1 - Net to collect olives.
2 - tree already clipped.
3 - tree view... literally! (upon tree)
4 - productivity.
« Reply #250 on: November 19, 2019, 01:26:34 PM »
Hi Sp
Nice work, nice photo's.
What do you do with the olives?
sirpedrosa
« Reply #251 on: November 19, 2019, 02:17:59 PM »
Hi Stef
Each 350 kg provides a complete olive paste press. I usually get 10% extra virgin olive oil. A few kgs are salted and preserved to serve as table "hors d'oeuvre".
VP
« Last Edit: November 19, 2019, 06:21:02 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - Almost done
« Reply #252 on: November 20, 2019, 09:48:24 PM »
Hi Gentles
The beast is dressed. Only need to be bleeded and oil pump primed.
2 pics to amuse...
VP
1 - Hot water manifold detail.
2 - general view.
« Last Edit: November 23, 2019, 03:07:07 PM by sirpedrosa »
sirpedrosa
Resurrection of a Lister 12/2 - primed and bleeded, ready to fire up
« Reply #253 on: November 21, 2019, 10:17:54 AM »
Hi Gentels
All baskets are empty, just left the old hose clamps.
It's ready to fire up...
VP
pics:
1- basket;
2 - Do you remember my Braims oil can?
3 - And our friend syringe? Bleed is bleed, isn't it?
sirpedrosa
Lister 12/2 ALIVE - 21NOV2019
« Reply #254 on: November 21, 2019, 07:16:32 PM »
Hi my Friends
First of all I'd like to thanks to all of you, whom helped me to reach this mile stone.
THE LISTER IS ALIVE!
4 pics and the link to 2 vids starting cyl 1 and cyl 2.
Cylinder 1 starting: https://drive.google.com/file/d/19icG0EaDB67yH_wLljhglXsW1nyKESBo/view?usp=sharing
Cylinder 2 starting: https://drive.google.com/file/d/1mk67GVyECd4eY0EDzCZ4OsBGyU82oe-W/view?usp=sharing
Couldn't start both cylinder at same time, because I realised it was to much kinetic energy to that casters in order to run steady.
Next step: making trolley and cooling tank.
VP
« Last Edit: November 21, 2019, 08:43:22 PM by sirpedrosa »
