Sounds like some Australians are more safety obsessed or electro phobic than Americans.
Admittedly, 230VAC does have a bigger bite, but the case can be made that Darwin should have his way for those intent on bathing with corded appliances or operating corded power tools in puddles. Electrocution by folly in the home (not construction worker or electrician or equipment operator) is extraordinarily rare (8 per year in 325 million). There are 4x more deaths per year by lighting than electrocution, even allowing for 8% suicide by electrocution. For us to all incur the cost and environmental impact of preventing such an unlikely situation is, well, foolish. It is the peddling of fear for profit.
The improved safety of GFCI, AFCI or RCD breakers is not a problem- the profligate power use and conducted EMI is.
If there was a new standard for 12 or 5VDC supply in the breaker box, and a limit for allowable power use, the power consumption could easily be reduced dramatically. Again, the problem is the replication of tiny switching supplies for every frigging breaker, and the EMI injection onto the home power from those poorly designed supplies. Just as in LED lighting, a single well designed and filtered supply would dramatically improve things.
I've been using Microchip's 5v op amps and analog comparators in my designs of the last 10 years- insanely low power use of 0.010 ma/channel. With 4 on an IC plus a bit extra, a breaker should be drawing 0.1 ma or less of 5V, or 5 uW each.
20 breakers would then be drawing 0.1 mW, not 60,000 mW (60 watts). It is utterly foolish too replicate the power loss of a small 5V power supply for every damn breaker, and design them without concern for power consumption when they are a 24/7 load.
Alas, we seem to be using Neanderthals for our entire power system design.
