Mine did not come with the Wall box, and these were not attached to anything. I applied 12 v across it and noticed that the plunger popped up. So how would I best work it?
I figured that once the SOM started to spin up it would produce some power causing the plunger to rise pulling the exhaustlifter and the fuel rack. The motor should be ready to start them but I would still need to manually open the rack... am I correct??
The micro swtich seems to be holding the Governor arm up, can I take it off?
Also I noticed that the governor arrangment seems to be jamed up and it does not move much. Cant see how to adjust it.
I was thinking that if I had a normally closed switch, then opening it would de-energise the solonoid causing the engine compression to open and the fuel rack to close stopping the engine. Closing it and energizing the Genhead with a battery to get it to spin up, which would energize the solonoid allowing the engine to start.
If I am wrong, out to lunch, let me know... I just guessing here
