Author Topic: Pulley  (Read 2495 times)
queenofjacks
Pulley
« on: March 17, 2018, 05:14:18 PM »
Hello, all-
  My NEW Listeroid project is moving right along.  I seem to have run into a stumbling block, however, in my search for a pulley.  I need a 7 to 8 inch diameter 8 rib split taper pulley ( or something close -- 1 1/2" generator shaft).  If anyone has something close to this or can point me towards a source, I would really appreciate it!  Thanks! -- Charlie
Lovson 10/1  7.5KW - Power Solutions 20/2  12KW - Lister SR2 7.5KW - 2-Lister 8/1's - Lister TR2 7.5KW
Re: Pulley
« Reply #1 on: March 17, 2018, 07:07:35 PM »
We stock heavy billet pulleys in all sizes to 15". Some in L8 and some in K8 grooves. We also have the K and L belting.
gary@dieselgen.com
George A
Re: Pulley
« Reply #2 on: March 18, 2018, 10:52:55 AM »
I used the crankshaft pulley from a Chevy 350 with a machined adapter hub, however it's a 6 rib if memory serves. It measures 7 3/4", so allows the engine to run at 600 rpm and power a 2500 watt generator.
Re: Pulley
« Reply #3 on: March 18, 2018, 04:59:58 PM »
They are rare and hard to find as Rockinghorse do do here Garry.
There should be a good business in promoting those things as i have read of people in the us having a hard time finding them as well.
It takes a fair investment, but these things can be easily produced and machined once specs are arranged. I don't think we've sold more than a half a dozen in the past year... fairly dead stocks.
kdct
Re: Pulley
« Reply #4 on: March 19, 2018, 01:25:04 PM »
In 2011 I got mine from Mike Montieth (alternateenergy at bellsouth.net). Don't know if that e-mail works any more. It was a custom 9.5" 8 rib K series. Very reasonable. It needs a SK taper bushing to mount it.
Re: Pulley
« Reply #5 on: March 19, 2018, 03:47:10 PM »
Ours use the SK QD bushings as well, so they can be matched to many different shaft sizes and are easy to install and remove.
