How to / DIY > Engines
small end bush
iann:
how do i remove the small end bush from the con rod on a 6/1 CS. suppose there is a special tool.
thx ian
GuyFawkes:
Fly press and correct mandrel
http://www.abana.org/ronreil/flypress.shtml
_well_ worth a read for the yanks
VASTLY under-rated tool, can do things you can NEVER do with a hydraulic press.
bit like listers, actually about 100 x as clever as it looks
Jackpine Savage:
Note: I'm not a machinist or a mechanic but am trying to learn!
On this side of the pond arbor presses seem to be more common. I'd never heard of a fly press before. What are the pros and cons of each?
http://www.greenerd.com/arbor.htm
Andre Blanchard:
--- Quote from: Jackpine Savage on July 28, 2006, 03:35:19 PM ---Note: I'm not a machinist or a mechanic but am trying to learn!
--- End quote ---
You get that big flywheel spinning and when the ram hits, things move, or break.
With an arbor press all you can do is get a longer pipe to put over the handle. Arbor press is a bit faster for repetitive light duty work like a push broach for a keyway.
GuyFawkes:
--- Quote from: Andre Blanchard on July 28, 2006, 04:05:47 PM ---
--- End quote ---
--- End quote ---
nooooooooooooooo
flypress you can adjust, as exactly as you like.
a/ stroke length
b/ stroke speed
c/ stroke force
flypress is absolutely PERFECT for jobs like inserting or removing bushes, bearings, inserts, you name it, also great for punching, bending, forming and all sorts of other kinds of metalwork.
quite apart from the fact NO POWER SOURCE required, you can do everything from punching a 0.5 mm hole in a fresh egg to a 500 ton impact on the same piece of equipment, bed metal into rings of any diameter you like, make folded damask / katana type metals, cut, punch, shape, form, peen, swage, and even WELD with a flypress.
read the link I gave.
