Author Topic: small end bush  (Read 17235 times)
iann
small end bush
« on: July 25, 2006, 10:43:48 PM »
how do i remove the small end bush from the con rod on a 6/1 CS. suppose there is a special tool.
thx ian
1953 lister CS 6/1, lister B, Villiers XIIc, Seagull 40+ outbourd
GuyFawkes
    • stuff
Re: small end bush
« Reply #1 on: July 26, 2006, 12:03:16 AM »
Fly press and correct mandrel
http://www.abana.org/ronreil/flypress.shtml
_well_ worth a read for the yanks
VASTLY under-rated tool, can do things you can NEVER do with a hydraulic press.
bit like listers, actually about 100 x as clever as it looks
Jackpine Savage
Re: small end bush
« Reply #2 on: July 28, 2006, 03:35:19 PM »
Note: I'm not a machinist or a mechanic but am trying to learn!
On this side of the pond arbor presses seem to be more common. I'd never heard of a fly press before. What are the pros and cons of each?
http://www.greenerd.com/arbor.htm
Andre Blanchard
Re: small end bush
« Reply #3 on: July 28, 2006, 04:05:47 PM »
You get that big flywheel spinning and when the ram hits, things move, or break.
With an arbor press all you can do is get a longer pipe to put over the handle.  Arbor press is a bit faster for repetitive light duty work like a push broach for a keyway.
______________
Andre' B
GuyFawkes
    • stuff
Re: small end bush
« Reply #4 on: July 28, 2006, 04:46:58 PM »
nooooooooooooooo
flypress you can adjust, as exactly as you like.
a/ stroke length
b/ stroke speed
c/ stroke force
flypress is absolutely PERFECT for jobs like inserting or removing bushes, bearings, inserts, you name it, also great for punching, bending, forming and all sorts of other kinds of metalwork.
quite apart from the fact NO POWER SOURCE required, you can do everything from punching a 0.5 mm hole in a fresh egg to a 500 ton impact on the same piece of equipment, bed metal into rings of any diameter you like, make folded damask / katana type metals, cut, punch, shape, form, peen, swage, and even WELD with a flypress.
read the link I gave.
Andre Blanchard
Re: small end bush
« Reply #5 on: July 28, 2006, 05:15:46 PM »
nooooooooooooooo
a/ stroke length
b/ stroke speed
c/ stroke force
I did not say you could not use a flypress with finesse. ;)
I just said you can spin that flywheel up storing a lot of energy and hit shit hard, something you cannot do with an arbor press.
______________
Andre' B
GuyFawkes
    • stuff
Re: small end bush
« Reply #6 on: July 28, 2006, 05:27:41 PM »
or a hydraulic press, or anything else except the old flywheel and crank factory presses
http://www.gandmtools.com/cat_branch.php?sub=14
oldnslow
Re: small end bush
« Reply #7 on: July 28, 2006, 06:24:08 PM »
I had good results with an arbor press and properly sized mandrel, but on other diesel engines not listeroids.  Last time I just let a machine shop do it. I gave them the new bushing and the wrist pin. The rod was returned to me with the new bushing installed and reamed to the proper size.
I must say though, that fly press is killer. Bookmarking that page.
Mistakes are the cost of tuition.
Re: small end bush
« Reply #8 on: July 28, 2006, 06:40:01 PM »
if you are contemplating replacement of the rod end bushing, you might consider letting a machine shop do the work, reasons are
1. they are tooled to not only remove and replace the bushing, but are also equipped to ..
    a. size the bushing properly to your wrist pin
    b. straighten a tweaked rod
    c. check alignment and resize the big end as needed.
all of which maybe be sorely lacking with the original rod from an indian manufacture.
the cost of which is not that bad, i would expect an engine machine shop could do it for 20 or 30 bucks, and you have a quality finished product.
also they can magnaflux the rod and make sure is has no cracks, and for a bit more can match a pair for weight, remove flashing, and shot pean if you like.
all of which (according to the individual) may or may not be required.
probably not a repair most folks should endevour to do, we aren't talkin about an air compressor rod or a lawn mower, but a diesel with significantly higher stresses and loading.. done wrong and you set yourself up for more grief
Andre Blanchard
Re: small end bush
« Reply #9 on: July 28, 2006, 07:03:39 PM »
Just in case you did not find your way to this page from Guy's link.
The links from this page show some of things you can do.
http://oldworldanvils.com/flypresses/tooling_index.html
I need a bigger shop. ;D
______________
Andre' B
