Actually, thinking about full flow oil filtering in these older engines, its probably not a good idea. Given the shocking state the oil gets into, a filter would tend to block rather quickly and make things worser real quick. All the engines I have had have survived shitty oil over decades of use with no problems, as many here will attest after working their own
Filters too will shred if there is moisture in the oil, which, in CS Listers at least is a given, as the oil runs luke warm at best.... never drives out the water with heat.
In saying that, a bypass filter may be a better option, and wont deprive the engine of lubrication if it blocks up, but then it wont be effective either in that case.
Im inclined to think Lister knows best and leave them like they are.
