A large degree wheel can also be helpful, although not strictly necessary. I do like the practical approach that 38ac covers in his write-ups. Look at the WOK section.
Okey-dokey. Thanks, Dieselgman, folks, for all your advice(s), this is what I did
(and excuse me again while I am long-winded, sorry)
Step one - used the vernier-down-the-injector hole to find TDC - rotating the engine in both directions. The two marks are about 6mm (one degree) apart so that will do.
Step two – my good steel tape says the flywheel is 1906mm in circumference; and George’s Utterpower spec page says the 23.5 inch wheel is 1887mm in circumference. So that will do.
(1906 divided by 360 = 5.2944mm per degree)
Step three – using your recommended technique (valve opening begins when the pushrod tightens up and valve closing ends when it comes loose again) I marked my actual Intake Open, Intake Closed, Exhaust Open and Exhaust closed on the flywheel with a big black felt pen
(Newbie/idiot comment: Rotation is clockwise if I am facing the flywheel on the injector/oil pump side, and thus, say, the mark for the nominal opening point of the intake valve at 4-8 degrees BTDC is 4-8 degrees CLOCKWISE - ahead - around the flywheel?)
Your specs say:
Intake Opens 4-8 degrees BTDC say 6 degrees nominal
Intake Closes 14-18 degrees ABDC say 16 degrees
Exhaust opens 42-48 degrees BBDC say 45 degrees
Exhaust closes 6-10 degrees ATDC say 8 degrees
Now, I don’t have a degree wheel but I can measure, calculate and count. So, if TDC is 0/360 degrees, then:
I.O. nom. 354 degrees?
I.C. nom. 196 degrees?
E.O. nom. 135 degrees?
E.C. nom. 8 degrees?
These are good nominal points if my calculation is OK
Measuring my markings around the flywheel (actuals garnered by the “when the pushrod tightens up/comes loose” method - so not TOO bad probably – gives me these figures below
(not corrected in any way):
I.O. at 105 degrees – 111 degrees ahead of nom at 354
I.C at 308 degrees – 112 degrees ahead of nom at 196
E.O at 273 degrees – 138 degrees ahead of nom at 135
E.C at 95 degrees – 87 degrees ahead of nom at 8
I had previously set the valve clearances at TDC as per advice at 0.017 (my 0.45mm feeler gauge) and 0.032 (my 0.8mm feeler gauge)
They seem like very big gaps but I take on board the wonderful 38ac lecture on valves/lash/timing/breathing . . .
(Just a thought that if my ACTUAL exhaust valve duration is from 273 degrees to 95 degrees – fully open around 6 degrees perhaps, depending on cam profile – no wonder the valve hits the expletive-deleted piston?)
(I haven’t figured a way to copy/paste images onto here, otherwise I would post one showing the line on one tooth of the cam gear nestled between the dots of two teeth of the idler gear)
Looking at the above makes me wonder if my cam train’s timing is maybe 90 degrees out of whack or something similar?
I guess next I’ll pull a main bearing housing off and check the drive gear-to-idler gear marks?
Do I have my thinking right or are there some Newbie Dumb Assumptions being made here?
FWIW I am a 59-year-old engineer who grew up with old pushrod/points/carbs Bedford trucks, and spent a chunk of life repairing sawmill machinery; so while the Lister Diesel is unfamiliar to me, many of the concepts are not . . .
I’m interested/amused that this engine was sold to me as “used to run OK, won’t take much to get it going . . . .”
Once again I appreciate the interest and advice
