Author Topic: Charging a 6 volt off grid?  (Read 6851 times)
xyzer
« on: April 20, 2016, 12:32:46 AM »
I have an off grid place with 12 volt solar + diesel generator. I also have a tractor there that has a 6 volt system and I want to keep the battery in a fresh ready for business state. Having the odd voltage around makes it hard to do this. A small solar system will do but finding a small but not to small panel is difficult. My question is would putting a 1.5 watt 12 volt panel cause the battery harm. I have a friend that does this with his and it seems to do fine. A suggestions appreciated!
Dave
Vidhata 6/1 portable
Power Solutions portable 6/1
Z482 KUBOTA
Re: Charging a 6 volt off grid?
« Reply #1 on: April 20, 2016, 12:47:45 AM »
If I may make a suggestion, convert the tractor to 12v and put an orbital battery like an Optima in it. The orbital battery chemistry has a much, much lower self discharge rate, so you can come back after 9 months and it will crank right up. The 6v starter will do just fine on 12v, unless you're cranking it really hard for a long time. A charging system to keep a FLA battery at a good state of charge will eventually boil the water out of it causing the dead battery issue you're trying to prevent in the first place.
« Reply #2 on: April 20, 2016, 02:00:02 AM »
We sometimes used 6-volt starters with 12-volt batteries in older VWs. They would do just fine as long as we swapped the 6-volt solenoids for 12-volt versions. Many starters have common parts like this readily available. The motors would crank at a faster rate, but I don't believe we experienced any motor failures with this setup even after extended periods. Of course the battery charging systems had to be updated to 12-volt... another easy swap of parts would suffice.
Thob
« Reply #3 on: April 20, 2016, 02:53:07 AM »
I have a 9n Ford that was 6 volt and I put a 12 volt battery in it.  I changed the starter relay to 12V (no solenoid).  I changed out the generator for a 12V alternator (bought a kit including alternator, proper pulley, bracket, etc.)  At first, I added a resistor in the ignition but it needed a new set of points every year.  So finally I updated it to a 12v coil and electronic ignition.  It has been working this way for several years now.
That's a lot of work and fair bit of change, so to answer your original question, yes you could put a small 12v solar panel on it.  They typically only put out a fraction of an amp, and will work just fine at 6V.  I don't have a good answer as to how long your battery will last, my experience with batteries has been all over the map.  But it works for your friend, it should work for you as well.
There are also some simple charge regulator circuits that could be built with an LM317 and a few components.  I think there's one in the LM317 datasheet, I don't know if you're into building your own or not.  It could be powered from its own solar panel or powered off of your existing 12v system.
« Reply #4 on: April 20, 2016, 05:48:57 AM »
... would putting a 1.5 watt 12 volt panel cause the 6v battery harm.....
Not likely.
A 12v 1.5V panel can deliver 15V @ 0.1A (100ma)  (W / V = A)   [A 12V battery needs 15V to charge, typical "12" v panels are close to 15-18V]
A 6V 80Ah battery [ my guess at a smallish tractor battery ]  could easily absorb 100ma of "trickle charge" for months.  You would have to check water
levels and likely add distilled every other month to top it off.    PV panels are current sources, and attaching a 12v panel to a 6v battery just wastes half the power
and is unlikely to overcharge the battery
« Reply #5 on: April 20, 2016, 06:19:35 AM »
You should be OK if the 12V nominal panel is small enough current.  (<100ma) The upside is you get to use very small wire, since can afford LOTS of voltage drop.
You could play it safe and use a fixed 7V regulator like: BA17807T-ND at Digikey.  It will need a heatsink because of all the voltage drop.
On some panels you could drop the voltage by shorting the bypass diode on the back of the panel.  Or you could just cover some cells.
« Reply #6 on: April 20, 2016, 07:17:50 PM »
How about one of those $25 solar trickle units from eBay or Amazon?  A small resister or 50 feet of line spliced in might be needed to drop that 14 or so volts down to 7 or 8.  Or shade part of the panel?  This is to just keep the 6 volt battery topped up - right?
I'd probably just stick a 12 volt battery in there as suggested above only just wait and see what happens down the road.  Yeah, my folks were hill-folk.
Casey
« Reply #7 on: April 20, 2016, 07:50:15 PM »
Why not just pick up a 6v solar panel?
« Reply #8 on: April 20, 2016, 08:07:22 PM »
Here's a cheap 6v PV regulator:
http://www.amazon.com/Controller-Battery-Charge-Regulator-Intelligent/dp/B0191QN8RA/ref=sr_1_1?ie=UTF8&qid=1461178626&sr=8-1&keywords=6v+solar+panel+regulator
Might work fine on your 12v panel, though they do have some small (half amp) 6V panels at amazon also.
http://www.amazon.com/gp/product/B0091PU5TG/ref=s9_simh_gw_g107_i1_r?ie=UTF8&fpl=fresh&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=0RT5GVHSE7PTVJC8R3WJ&pf_rd_t=36701&pf_rd_p=2437869742&pf_rd_i=desktop
Bit of a rip off for just 3.5 watts!  Some foil tape on a 12v panel might be cheaper.  Test with post it notes.
Some of the best bargains on solar panels are at Solarblvd.com.  Some of the non big brand panels may not meet the marketing spec for output. Be prepared to test if you really need full capacity.
xyzer
« Reply #9 on: April 20, 2016, 10:09:02 PM »
Bruce, and all
Good find on the 6v panel! I am going to use a 12volt and some tape to back it off a bit. Changing over the tractor to 12 volt is a bit more than I want to deal with. I just bought a new 6 volt battery so I'm going to put a small 12volt on it and cover a bit of it.
Thanks again!
Dave
Z482 KUBOTA
Quinnf
  • Rest in peace
« Reply #10 on: April 22, 2016, 05:15:30 AM »
Back in my ham radio days, we used to charge 12V Ni-Cd battery packs for our portable radios using a #53 light bulb run off a 12V car electrical system as a mobile charger.  Worked great.  Current tapered off to zero as the battery pack came up to charge, and the light would go out.
EdDee
« Reply #11 on: April 22, 2016, 09:49:39 AM »
Interesting thing I saw the other day...
El cheapo, Chinese taser cum cattle prod.... to charge, it simply decoupled the mains input with a capacitor on one line and straight thru a bridge rectifier to a battery pack.... I don't think it is possible to get a more horrible a charger than that.... Strange enough, the rest of the unit has fallen apart from a mechanical standpoint but the electronic/electrical side is still 100%...
Ed
« Reply #12 on: April 22, 2016, 04:23:47 PM »
Using a capacitor from the mains to reactively limit current and voltage is commonly used in cheap LED lamps as well.  You get about 0.050 amps (50 ma) per 1 uF at 120VAC 60Hz. Rectify it and away you go.
For small amounts of power it can be cheaper and more compact than a transformer.  Power factor is of course horrible.
