How to / DIY > Generators
SR2...just picked up another one.... :-)
<< < (2/4) > >>
guest23837:
I believe the anti-clockwise engine means you can close couple the alternator. I been reading everything I can find about engines and generators as I'm trying to build one!
dieselgman:
Generator heads - alternators can turn either direction. The Lister industrial engines turn anti-clockwise while the marine types turn clockwise. Marine propulsion normally runs through a gearbox which reverses rotation.
quinnbrian:
--- Quote from: dieselgman on February 23, 2016, 01:12:32 AM ---Generator heads - alternators can turn either direction. The Lister industrial engines turn anti-clockwise while the marine types turn clockwise. Marine propulsion normally runs through a gearbox which reverses rotation.
--- End quote ---
So what about adding a started....does it have to be anti-clockwise starter, or do i need to find a Lister genhead, with the starter built in.
dieselgman:
Yes, you must install a DC starter of the proper rotation matching your engine... they are not reversible.
guest23837:
More bad info on the net! I read an article that said the cooling fan in an alternator only worked in a clockwise rotation
[*] Previous page
