Author Topic: SR2...just picked up another one.... :-)  (Read 8923 times)
EdDee
Re: SR2...just picked up another one.... :-)
« Reply #15 on: February 25, 2016, 08:28:20 AM »
Hi Mike,
I had similar happen.... My 12/1 has a 220v fan on the radiator(2 actually)... When I installed the Auto changeover for the output on the alt to overcome the utility, I lost one brush wire on the alt... I didnt notice because the utility power kicked in and powered everything... the fans of course, stopped running, engine was ticking along unloaded for about an hour with no forced draft cooling under minimal load... There actually wasnt much heat generated.... The radiator was hot, too hot to touch comfortably, but certainly not boiling.... Day temp was around 30C if I remember.... The little bit of air wafting about by the flywheels was pretty much enough to stop disaster....
Do a test... let it run, unloaded, for a reasonable time, no fan, and see... You might be surprised....
Ed
quinnbrian
« Reply #16 on: February 28, 2016, 01:56:26 AM »
I' going to have to put this project on hold for a bit...other things have come up, that are more pressing.
Thanks for looking , will get back to this project at a latter date.
Brian
KC7NOA
« Reply #17 on: January 26, 2022, 11:43:32 PM »
Old thread, sorry .....
How did you get on with the starter?
Did you find a suitable replacement?
KC7NOA
« Reply #18 on: April 29, 2022, 07:33:41 PM »
Hey ... im close to getting a similar situation resolved...
Still looking for the correct ring ...
I have a video ov my sr2a running ( you tube kc7noa lister sr2 -- starting with a rebuilt original starter
