Author Topic: HR2 info please  (Read 6570 times)
nuttyprofessor
HR2 info please
« on: February 21, 2016, 04:38:41 PM »
Hi Guys,
Haven't been on here for ages, haven't needed to as the old ST3 had been behaving itself. It finally gave up after running for 5 years for up to 8 hours a day.
Anyway now have a 1976 HR2 with 15kva alternator, believe it to be ex MOD and only has 500hrs use.
After building a sound proof shed and underground exhaust system it run perfectly for 2 days (about 8hrs) on the 3rd day it was chucking out a lot of white smoke which I believe was un-burnt fuel, believing the bores where glazed I fully loaded it and sprayed a mist of water down the inlet. This cured the white smoke but after a couple of weeks running it's still blowing a small amount of blue smoke and using a bit of oil.
I want to change the oil but I totally confused after reading loads of threads on the subject which all seem to contradict one another.
I can't get the 20/20 stated by Lister out here in France (looked everywhere) some threads suggest 15/40???
Your vast knowledge would be much appreciated on this much talked about subject.
Also any other advice on running this HR2 would be greatly received.
Thanks in advance
If it ain't broke tinker with it anyway!
Lister ST3 coupled to Brush alternator
Gravity defying lawnmower
30 year old 1.5 ton mini digger
Mitsubishi Evo 1
And a stunning wife who puts up with all my junk!
Re: HR2 info please
« Reply #1 on: February 22, 2016, 12:21:37 AM »
15/40 diesel rated oil is fine for your HR. That engine model really does not like to run cold (lightly loaded). Blue smoke indicates oil pumping past the rings but white generally will be related to fuel injection malfunctioning. They can be a bit fussy with sticky nozzles and such often caused by contaminants coming through the fuel system- difficult to get tuned and settled down, but run long and hard once the bugs are out. I can recall going through 3 sets of injectors on one of them before finally getting properly balanced power from both cylinders.
nuttyprofessor
Re: HR2 info please
« Reply #2 on: February 22, 2016, 01:27:06 PM »
Thanks for the help dieselgman. I'm running at about 3/4 load. It is possible that smoke is paint burning off form inside the exhaust I built... I'll give it a few more week after an oil change and then strip down and have a look and glaze bust at same time.
Mitsubishi Evo 1
camillitech
    • life at the end of the road
Re: HR2 info please
« Reply #3 on: April 01, 2016, 10:42:26 AM »
Hi Guys,
Thanks in advance
Sounds like the same HR2 I've got, ex MOD 15kVA from a satellite tracking station, fine machine if not a tad noisy. Have you been a little over enthusiastic with your silencing? Lister are very specific about exhaust diameters, back pressure and pipe length. http://www.winget.co.uk/document/R.A.%20LISTER%20HR3%20WORKSHOP%20MANUAL.pdf See page 6 about diameter/length and back pressure. Too much back pressure could well be the source of your woes.
Good luck, Paul
http://lifeattheendoftheroad.wordpress.com/
HR2 Lister 12Kw
ST2 Lister 7Kw
SR2 Lister 6Kw
SR1 Lister 3Kw
nuttyprofessor
Re: HR2 info please
« Reply #4 on: April 12, 2016, 04:26:45 PM »
Thanks for the link mate, very helpful
Mitsubishi Evo 1
